Air inflator/fuse watt for car
Old Nov 28, 2012 | 02:33 PM
CloudStrife's Avatar
CloudStrife
Since I'm no longer running run flats, I decided to look into purchasing a tire inflator to have with me in the car just in case I can't make it to a gas station. Plus I would like to use it for my spare and since it needs to be at 60psi at all times I would sometime that can blow it up without exploding or taking 2 hours.
Any thoughts please and thank you?
Old Nov 28, 2012 | 03:25 PM
Capt_bj's Avatar
Capt_bj
huh?
buy a real compressor . . . even a small pancake compressor will meet your (cryptic) requirements
Old Nov 28, 2012 | 03:27 PM
ZippyNH's Avatar
ZippyNH
Most any 12v pump that plugs into the lighter will work....might take 3 or 4 minutes, or a minute to add some air, but i have owned 2 or 3 over the years, and they are about the same.....i'm guessing cause the little dc motor that opperates the compressor is limited to the 180 watts or so a car's cogrette lighter can provide.
Old Nov 28, 2012 | 03:56 PM
CloudStrife
Yeah but you can't really take those with you all the time. And I already have one that won't inflate my spare
Old Nov 28, 2012 | 03:58 PM
CloudStrife
Slime makes a portable air comp like inflator, don't know how we'll that would work tho. Wonder where I can find out how much our little cig lighter puts out
Old Nov 28, 2012 | 04:14 PM
Chimera's Avatar
Chimera
I use the Slime one since I switched to non-runflats and it works fine if a little slow (I'd say about a minute per lb adding air). One thing I've found is that the compressor runs much faster if the engine is running rather than just the accessory circuit.
Old Nov 28, 2012 | 04:44 PM
ZippyNH's Avatar
ZippyNH
The little pumps i have...one says 100 psi max, the other says 150...kinda doubt the 150, but both had warnings that they should not be used on large "truck" tires, and have a 15 minute max runtime....i have run them for 5 minutes or so...all it took with inflating from 15 to 30 psi when i did my winter changeover....i did have to physically hold the connector to the tire to get a good seal, bit it worked fine.
Old Nov 29, 2012 | 08:10 AM
CloudStrife
The slime seems nice from the reviews I've read, but you can screw it on to get a tight seal
chrisx18240
26
Mar 16, 2022 09:56 AM
Wohnson89
Jun 10, 2020 04:53 AM
Zettinger
Aug 25, 2015 04:04 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
