Suspension Rear Passenger Side Corner Sitting Lower?
My friend installed my NM Engineering springs on my 09' Clubman S a few weeks ago. The passenger side rear corner sits noticeably lower than the drivers side rear corner.
Today I parked on a level surface and measured from the sidewalk to the beginning of my fender, with the tape measure going up the middle of the wheel.
There is only 1cm difference, but its noticeable. Not sure if its normal for the ride to slightly rougher and noisier as well?
Here are the measurements:
Front Drivers Side: 63cm
Rear Drivers Side: 64cm
Front Passenger Side: 63cm
Rear Passenger Side: 63cm
I can fit 1 finger between the tire and fender on the rear drivers side, but cannot on rear passenger. It's also worth mentioning I purchased these used from someone here on the forum.
Any ideas guys? Thanks!
Unfortunately I didn't measure pre-install, but never noticed anything like this.
I am just curious to know if there is anything in particular that could have gone wrong during the install resulting in this.
Interior/Exterior Need Help With Exterior Decisions (05' MCS PHM/W)
boostedhaze
Jan 2, 2018 07:26 PM
Cal45fan
Aug 11, 2015 03:50 PM
