After new hub the wheel speed sensor does not want to cooperate
Old Nov 24, 2012 | 06:38 PM
godzilla's Avatar
godzilla
I finally finished changing the hub but now i Can't get the wheel speed sensor to go in
Old Nov 24, 2012 | 07:28 PM
godzilla's Avatar
godzilla
I put a bolt down the hole and it is clear except for a little indention near the bottom where I assume the flat part of the sensor fits.
I thought I'd tighten the screw and tap it in with a screwdriver and the stupid plastic mount broke in half.
It just won't go in and my patience is gone.
Enough for today.
I guess I'll try to epoxy the mount back together tomorrow.
But what would make the sensor so hard to go in?
Old Nov 28, 2012 | 04:09 PM
godzilla's Avatar
godzilla
Bump
Old Nov 29, 2012 | 07:04 PM
dubstepsteve's Avatar
dubstepsteve
i had the same problem. it could just be corroded in the hole just take a wire brush and clean it out real good then spray some lub on it and try to press it in. i wouldnt tap on it tho its too easy to break
Old Feb 10, 2013 | 05:35 AM
godzilla's Avatar
godzilla
Turned out it was the dust ring on the back of the wheel bearing. It had gotten bent just enough to keep the sensor from going back in place.
SosoMINI
Nov 22, 2015 03:17 PM
minicoclub
Nov 11, 2015 07:25 AM
Dashdog
Aug 10, 2015 06:17 AM
MES11
Aug 8, 2015 10:21 AM
