R55 Clicking sound. Is that a bad timing chain?
Old Nov 24, 2012 | 04:04 PM
mojoe_24's Avatar
mojoe_24
So I've been getting a bad clicking sound with the car running. Is that a bad timing chain? How important is it to fix right away? Is only the sound the problem or can it cause mechanical issues as well?
Old Nov 24, 2012 | 05:08 PM
jcauseyfd's Avatar
jcauseyfd
A clicking sound is probably not the timing chain. Timing chain sounds like pebbles in a tin can. If it is the timing chain, the rattle is a symptom of a mechanical issue that already exists, so you would be driving on borrowed time. Any possibility you could pist a video?
Old Nov 25, 2012 | 09:10 AM
mojoe_24's Avatar
mojoe_24
Yeah, I'll get one today.
Old Nov 25, 2012 | 02:13 PM
mojoe_24's Avatar
mojoe_24
It usually sounds worst, but this is what I got
Old Nov 25, 2012 | 02:49 PM
jcauseyfd's Avatar
jcauseyfd
Video is marked as private.
Old Nov 25, 2012 | 03:04 PM
mojoe_24's Avatar
mojoe_24
Should be fixed.
Old Nov 25, 2012 | 03:09 PM
jcauseyfd's Avatar
jcauseyfd
jmo, but not the chain rattle. Pretty much sounds normal. Ticking may be a tad on the loud side, but could be location of the mic.
Old Nov 25, 2012 | 05:01 PM
mojoe_24's Avatar
mojoe_24
That's actually a lot quieter than normal too. I'm glad it's not the chain rattle though, I was kinda scared. I'll be taking it to the dealer soon because my service light comes one when I start the car. I think it's for the little (!) on the back of the car, though I have no idea what that means. I'll have them check out the sound when I take it though.
Old Nov 27, 2012 | 08:41 AM
kcle730's Avatar
kcle730
any update??
Old Nov 27, 2012 | 09:33 AM
mojoe_24's Avatar
mojoe_24
No. I haven't had time to go to the dealer. Most likely Friday.
Old Nov 27, 2012 | 10:00 AM
chucker1101's Avatar
chucker1101
Have you checked your oil level? Our mini makes this sound when oil gets to the low/extremely low level. We learned the hard way.
Engine oil level can drop well before any dummy light or warning comes on, as we found out. On the turbo models, oil can be comsumed by turbo blow back, meaning that it can dissipate faster. For comparison, my F-150 can go a year without losing any appreciable oil level.
It happened about 6 months after we changed the oil, and there was never a warning light that came on, even though we were low on oil. I hadn't been good about checking the engine oil level, and my wife drives the Clubman mostly anyway, so i didn't hear the noise until late, and when i heard it i didn't think much of it. It made the noise for about three to four weeks before the breakdown, according to my wife. Also, it kept getting progressively louder.
Fortunately we were under warranty - i can't remember exactly what happened, but a chain of some sort broke (not the timing chain), and the oil leaked out of the engine. It had to be towed away and fixed by the dealer.
Since this encounter, i've heard the noise again. And i immediately changed the oil, and the sound went away.
One other thing i remember about the noise, it tends to get quieter or go away after the engine is warmed up. But it makes the noise loud and clear when you start cold, and pull away from the curb.
Old Nov 27, 2012 | 12:21 PM
mojoe_24's Avatar
mojoe_24
I didn't think of the oil. I'll check.
Old Nov 27, 2012 | 03:20 PM
mojoe_24's Avatar
mojoe_24
I checked the oil. I didn't see any type of line saying full, but it went to the bottom of the highest cone thing. The place where you put in the oil (which I believe is separate) looks empty though. Not sure if it's supposed to be full.
Old Nov 27, 2012 | 03:56 PM
area49's Avatar
area49
Your oil level is probably ok if near the top of the graduations on the dip stick,
but if your not sure how to determine then let someone else check it.
They do get noisy with low oil and tend to disassemble with no oil, get it checked asap.
09R56
Nov 16, 2022 10:49 AM
TREX
Nov 2, 2019 07:31 PM
Svejk
Feb 24, 2019 12:18 PM
Aug 12, 2015 01:24 PM
iamcamkeenan
Aug 10, 2015 03:31 PM
