Xenon headlight losing brightness
Old Nov 18, 2012 | 07:08 PM
ofioliti's Avatar
ofioliti
Hi folks, one of my Xenon headlights seems to be losing its brightness. Instead of brilliant white, it has a less bright and very slightly red tinge. It has no problem lighting up; the color and brightness is just off. Does anyone know what the source of the problem might be? Is it's time near? (The MINI is almost 10 years old now. It is a 2004.)
Old Nov 18, 2012 | 07:24 PM
Bob Saget's Avatar
Bob Saget
Could be either a bulb coming close to the end of its life or a ballast going bad.
Does the light flicker at all or has it turned a different color than the other?
Old Nov 19, 2012 | 04:08 AM
yetti96's Avatar
yetti96
I would guess bulb by the description, but yes...does it flicker or have weird issues other than color?
Old Nov 19, 2012 | 04:48 AM
ZippyNH's Avatar
ZippyNH
One thing to remember about xenon bulbs...they are more of an arc light...life span is determined more by on/off cycles than hours of use...most give a slight shimmer/flicher when they light...than are fully bright.
Are the bulbs the orgional? Most oem's proclaim that a xenon bulb is good for about 10 years of typical automotive use....many/ most of the cheap e-bays replacents are a much lower grade...good for much less.
Old Nov 19, 2012 | 07:04 AM
ofioliti's Avatar
ofioliti
The color is slightly pink/red. It is the original bulb. I haven't notice any flickering while driving, but I will check later and see.
Thanks for the input, folks.
Old Nov 19, 2012 | 07:09 AM
dannyhavok's Avatar
dannyhavok
Any chance you're still on the original battery? I noticed recently one side was a little dim looking, but when I swapped in a new battery a week later the lights went back to normal.
Old Nov 19, 2012 | 08:12 AM
ofioliti's Avatar
ofioliti
Yes, in fact I am on the original battery. I will try replacing it first (about time, perhaps) and see whether the problem is solved. Thanks!
Old Nov 20, 2012 | 06:32 PM
ofioliti's Avatar
ofioliti
Well, crap, the bad xenon flickered (three flashes every three seconds or so) and never lit up this evening. I haven't done any research/reading up on this yet, so if anyone know what the problem is and what needs to be done I'd appreciate input. :-(
Old Nov 20, 2012 | 07:11 PM
Bob Saget's Avatar
Bob Saget
Definitely the bulb. Time for a replacement unfortunately.
Old Nov 20, 2012 | 07:36 PM
ofioliti's Avatar
ofioliti
Thanks.
Old Nov 21, 2012 | 04:20 AM
yetti96's Avatar
yetti96
To make sure you can swap the bulbs too and see if the bulb issue moves or stays in that headlight.
Old Nov 21, 2012 | 09:17 AM
jimz68's Avatar
jimz68
Bad bulb for sure. Both of mine went bad within a week.
Jim
Old Nov 21, 2012 | 11:44 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
+1, this'll help in making a more accurate decision than just replacing unnecessary parts.
888.280.7799 | 6am - 5pm PST
Old Nov 27, 2012 | 06:53 AM
Aspen's Avatar
Aspen
Bulbs.. Mine went pink about a week before it died. Buy two so the colours match.
Old Nov 27, 2012 | 07:24 AM
ViperNL's Avatar
ViperNL
Don't just buy 2 so the colors match, but because if one went the other will go soon too
Old Feb 12, 2013 | 08:37 PM
ofioliti's Avatar
ofioliti
Just an update: It was the bulb. I replaced both and the xenons are good as new. Purchased the bulbs for a good price at PelicanParts. Thanks guys!
j_parker
Nov 8, 2015 04:54 PM
ryGuyMCS
Oct 6, 2015 12:04 PM
molala
Oct 2, 2015 01:53 PM
dandw2
Sep 7, 2015 11:14 AM
dandw2
Sep 6, 2015 03:14 PM
