Suspension Creak/Groan
Old Oct 30, 2012 | 10:17 PM
kukaepe's Avatar
kukaepe
I've had a creak or groan sort of noise coming from the LF suspension of my '07 MCS for quite a while. It has been getting progressively worse and was happening every time I started from a stop and was making me nuts! I have searched NAM on numerous occasions and have not found any help. Well today I found the cause of the noise and thought I would share it. On the driver's side of the engine compartment there is a cast aluminum bracket that mounts to the uni-body that supports the left side of the engine/transmission assembly. By tightening the 3 bolts (13mm wrench size) using a "wobble socket" on an extension the noise is gone. I thought I was probably not the only 2nd Gen owner with this irritating sound so I hope this helps someone else who is bugged by this noise.
Old Dec 16, 2012 | 06:19 PM
trailrated's Avatar
trailrated
You are awesome. This was exactly the problem I had! Checked under the hood and one of the bolts was backed out an inch!
Thanks for this!
Old Dec 16, 2012 | 06:24 PM
RobMuntean's Avatar
RobMuntean
See I have a like a creak or rattle on metal sound on my left side(front) of my suspension. Every time I hit or go over a bump that's the only time you hear it but also when I'm backing out of the drive way, when I slightly get off the curb, the car makes the noise on my driver side. I am going to check it out now since you put this up, that might be what my problem is. Thanks!
Old Dec 25, 2015 | 07:29 AM
turbo tel's Avatar
turbo tel
Nope!!
I sometimes wonder what the heck I did before these Forums.. That creak I heard for the first time this morning (Christmas morning) On my 07 MCS would have driven me nuts.. Thanks kukaepe!! that cured it.
I suspect that after 8 years of my wifes gentle driving, my inheriting the car and thrashing it around for the last month was the final straw that loosened those bolts!
Terry
vulkandino
Oct 31, 2015 08:29 PM
GAT
Oct 4, 2015 07:27 PM
Tires, Wheels & Brakes
Oct 1, 2015 10:38 AM
Oct 1, 2015 10:17 AM
Emnotek
Sep 29, 2015 07:37 AM
