'12MCS coolant / cold start issues
Old Oct 30, 2012 | 01:33 AM
Summons's Avatar
Summons
(Hi All, I have reposted this here from the 2007+ R56 forum - I suspect this forum is more apropriate to the faults... Any help would be apreciated!! Thanks')
Hi folks,
I have mentioned this previously and have spoken to the dealer - the dealer was no help - insisted there was no problem, and the tech did not know what normal actually was... So here I am again!
Background: I have a 2012 MCS manual with 13000 Miles, and an EcoRoute HD module with a Garmin GPS. The car is otherwise stock in the engine compartment and related areas... I use the GPS primarily as a set of gauges to monitor coolant temp, battery voltage, intake temp, and boost. Timing advance is there too, but more for interest than any function for me. I recently had the car in for the coolant temp sensor replacement per the recall.
I have 2 related but (I suspect) different failures.
1.
Since very new the car has stumbled a bit at idle when cold. With coolant temps around 40-60C, when the engine slows to idle, it stumbles a couple times then settles. On a couple occasions, the car has failed to start, though this hasn't re-occurred in the last 8 months. After the coolant temp sensor replacement I did note a change on the Garmin - coolant temps never indicated below 25-30C even when the car sat out overnight at well below 0C. It now does indicate ambient temps (close to, anyways) at start up after a cold soak, but the stumble is still there.
BMW says all is normal... Can anyone report on how normal 'my' stumble is?
2.
This summer we had one day that got super hot - +35C or hotter (I know only 35C - we like it colder up here! ), and up until then I had always seen the same behaviour from the coolant temp on the Garmin: It would rapidly warm up to 102C and stay glued there unless I stomped on the gas - it would then plummet to 96C, stay there until I relaxed my foot, at which point it would race back up to 102C. I think I saw 103 or 104C twice up 'till that summer day, and below 96C only while warming up.
On that day, as I drove my usual highway route to work in open traffic, AC going, at the halfway point of my 20km drive, the coolant temp was still not at 102C but around 78C, and not climbing at all. Usually by then, I am at full temp, and my fun ramp from 1 highway to the other would induce the drop to 96C (what I was looking for) rather than seeing a low temp to begin with! It took until a km or so from work for the temp to GET to 102C (cycling the AC had no effect... ...on the engine - I roasted), and since then, it has fluctuated lazily - slowly moving up to 102 on warm up, generally holding the temp from 99-104C during steady driving, and dropping to less than 80C if I get aggressive with the throttle. I have seen 109C a couple times in stop and go traffic this summer.
Can anyone comment on the behaviour of their coolant temp - is it VERY steady at 102C with the expected drop to a lower value when driving spiritedly, or is my lazy thermostat normal? When I took a tech with me in the car to show him, he first off didn't know if the coolant temp indication on the Garmin was actually coolant temp (he suggested it might be some sort of calculated value or other mumbo jumbo), or how the engine was supposed to behave in any event! He did not know what 'normal' was.
Your help is appreciated!
Eric
Old Oct 30, 2012 | 01:49 AM
Summons's Avatar
Summons
As an addendum, with respect to the lazy thermostat, I really tried to make clear to BMW the CHANGE in the behaviour of the car on that day is why I am concerned. That and the impact of coolant temp fluctuations on the longevity of the engine. They pretty much ignored my comments... What the technician said, is that the computer would throw a CEL if there was in fact a problem. I have my doubts on that point, also I suspect I am seeing the start of a problem, and that a CEL is likely the point where I start doing damage to the engine - somewhat like the low oil pressure light...
Blink, blink, blink (you are damaging your engine), blink, blink, blink!
Thanks' again!
E
Old Oct 30, 2012 | 04:44 AM
ljmattox's Avatar
ljmattox
I have a 2/12 build MCS; I can confirm an occasional stumble on cold idle. Mine does this occasionally, not to the point where I was concerned about it. It is strong / smooth / fuel-efficient otherwise so I just consider this normal behavior for mine.
I don't have a water temp gauge to monitor, no feedback for you there.
iggi
18
Feb 9, 2026 01:00 AM
Melvinyip
Apr 17, 2020 09:28 AM
W0TM8
Dec 19, 2019 07:50 AM
TREX
Nov 2, 2019 07:31 PM
alistaircookie
Oct 8, 2015 10:52 AM
