Spark plug blow out #3 and now Dreaded P0303 code need help. MSD coil
Old Oct 22, 2012 | 04:09 PM
Braminator's Avatar
Braminator
Yes I have read numerous posting on this but I figured I will tell my story and maybe someone else had this happen.
I had the dreaded spark plug blow out in cylinder #3. I ended up having to put a new insert in as the threads were gone. When I tapped it out, I added grease to to tap and I would go a few turns back it out clean it off and re-grease it. I vacuumed out all the shavings which was very little from what I was able to see on top of the piston. I then put it back together and things were great for 3 days.
Today I got the P0303 code. I have a MSD coil and Magnacor wires. I just installed brand new NGK 4285 (BKR7EQUP) plugs. I had my scanguage clear the codes and restarted the car. You can feel the low rpm hesitation, but as you rev it it goes away. I know the check engine light will come on again.
So I am thinking of trying a new coil tomorrow, as I moved plugs and wires around with no luck.
Anybody got any other suggestions? I don't have a compression gauge to check the cylinder and I don't want to pull the valve cover unless I really have too.
Old Oct 22, 2012 | 07:15 PM
Braminator's Avatar
Braminator
Old Oct 22, 2012 | 08:44 PM
MiniMello's Avatar
MiniMello
so you tapped the plug hole with the head on and vacuumed the cylinder clean? It is very possible a small piece is in their and wiping out a ring, I would wonder if a cylinder pressure test or leak down would help here.
Old Oct 22, 2012 | 08:59 PM
slinger688's Avatar
slinger688
Is this for gen1? I think it is in the wrong section.
Most people seem to use time sert to fix this.
Old Oct 23, 2012 | 02:58 AM
daflake's Avatar
daflake
I believe you are right slinger...
If this is a 1st Gen, check and make sure your plug is seated and then check your wires and pack. I just dropped a screaming demon on mine and have noticed a difference (new pack made a huge difference over a pack with 98000 miles on it).
How old is your coil pack? How old are the wires?
Old Oct 23, 2012 | 04:08 AM
Braminator's Avatar
Braminator
Yes this is gen1 Sorry I posted in wrong area. I installed the MSD coil 24k miles 1 1/2 year ago with wires at same time. I just installed new plugs (4285 BKR7EQUP) 100 miles ago.
I am going to see if I can borrow a compression tester later today. I don't have another coil, but I will be picking one up later today also.
Old Oct 27, 2012 | 10:33 AM
Slave to Felines's Avatar
Slave to Felines
Does the starter sound "even" when it is cranking? I know that a "dead hole" (one zero-compression cylinder) will make for an uneven sound when the starter is cranking.
Compression testers aren't that expensive, so it might be worth picking one up.
Bublik
Feb 18, 2023 11:09 AM
maniacalmorgan
Jan 1, 2020 11:20 AM
maniacalmorgan
38
Sep 29, 2015 04:56 AM
Sikness
R57 :: Cabrio Talk (2009+)
Aug 20, 2015 06:00 PM
yashmack
Aug 15, 2015 10:16 AM
