R56 Flashing light dont turn off
When I turn flashing light left or right, after passing through corner they are not automatically turn off. On the service they told me that I have to change the whole Switch unit steering column.
Is anyone having this problem, does anyone have the wiring diagram of inside of Switch unit steering column.
Sounds more like a mechanical problem than electrical. I haven't taken apart the steering column on my MINI but on other cars I've tinkered with there has always been a tab in the steering column that cancels the turn signal after completing a turn. Might want to take a look and see what's wrong and if it's fixable without buying a new combination switch ($500+). After looking at my Bentley repair manual, it appears you will have to remove the steering wheel before you can remove the switch assembly; however, if you remove the airbag you can see the top of the switch and maybe you can then see what's causing the problem. Good luck.
Interior/Exterior DEPO/Helix Projector Headlights Installed
Alkaidovich
Jan 30, 2021 01:35 AM
Dec 23, 2015 10:36 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
