R50/53 Tails
Old Oct 13, 2012 | 01:06 AM
Draper84's Avatar
Draper84
Tails
Hey everyone, i was wondering if anyone knew if the tail lights from an 05-06 cooper s would fit into my 04 tail light spaces. I have a taillight that has much condensation.
Old Oct 13, 2012 | 02:02 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Wired differently but will fit. Since the 05/06's are of different style you will have to purchase both left and right. ( No more egg yolk look for those years )
When braking, the back up light inside the face lift tails will illuminate. But if you insert a red LED bulb in place of the clear one, you can get around that.
Old Oct 13, 2012 | 01:48 PM
04_Indi_Mini_S's Avatar
04_Indi_Mini_S
I was going to do this myself when I bought my MCS, but decided the euro tails look better so I ordered a set of the euros.
As stated above, the wiring is slightly different and causes incorrect bulbs to light up. There was a retrofit kit made for the conversion that solved this issue. Not sure if it is still available, but I did find the install guide. You should be able to use this and other info on NAM to get the wiring done correctly.
http://www.motoringfile.com/files/2005_taillights.pdf
Good luck!
OutMotoring
Mar 3, 2017 06:29 AM
Willafb
R55 :: Clubman Talk (2008+)
Nov 6, 2015 08:08 PM
vetsvette
Oct 15, 2015 09:04 AM
krohm
Sep 28, 2015 12:16 PM
whowantstorace
Sep 27, 2015 06:16 PM
