Electrical HID Swap..can it be done?
Old Oct 12, 2012 | 08:26 AM
mInIxsUbI's Avatar
mInIxsUbI
Fiance got a Countryman, but w/o the HID option.
If I were to purchase the OEM Xenon headlamp unit and just swapped the headlamps, would it work? I see there are a couple options (Bi-Xenon and AHL) and some statement about needing an ECU.
Old Oct 12, 2012 | 09:45 AM
yetti96's Avatar
yetti96
Being short and not rude, do some reading and searching. It is possible, but not cheap at all and there is some wiring involved (re pinning the plug) if you don't go the OEM upgrade route with the coding and extra module, possible wiper stalk, etc.
Old Nov 13, 2012 | 04:07 PM
Shoe Coupe's Avatar
Shoe Coupe
Short answer is yes.
But it is very expensive and you'd have to repin the plug, run new wires for an additional ground and also run new wires for highbeam. If you dont mind missing features, you can stop here.
If you want to do it right you'd also have to wire in two level sensors attached to the front and rear control arms and also replace the washer tank and tubing, add an additional pump so the headlight washers work.
Old Feb 4, 2013 | 03:18 AM
nexiss's Avatar
nexiss
what about the other way around I have oem Bi-xenon lights and want to install the standard oem halogens is there anything that i have to do the the wiring or can I just plug and play
Sep 29, 2015 12:17 PM
Sep 29, 2015 12:16 PM
Sep 29, 2015 12:11 PM
brucenick
Sep 21, 2015 12:37 PM
tylewis
Sep 6, 2015 07:36 PM
