New recall for the Engine coolant temperature sensor?
Old Oct 2, 2012 | 05:39 PM
NintenTom's Avatar
NintenTom
I received a email from the dealership I bought my car from today about a service campaign. Anyone else hear about this or what's up? I have a '11 R56 S.
From the email,
As I am sure you aware, MINIUSA has announced an "open service campaign" being to Retrofit the Engne Coolant Temperature Sensor.
DESCRIPTION OF PROBLEM
Internal corrosion could form in the engine coolant temperature sensor. This corrosion leads to internal bridging of the contacts, which can cause an inaccurate engine temperature reading. This false reading could lead to difficulty in the engine starting and/or a “Service Engine Soon” lamp being illuminated.
Old Oct 2, 2012 | 05:56 PM
Slave to Felines's Avatar
Slave to Felines
Yes, they're doing that for at least the 2011 and 2012 cars. I believe they replace the thermostat and thermostat housing as well as the sensor. I had my car in for other reasons (maintenance, warranty repairs on some smaller stuff) and they performed the service campaign as well.
Old Oct 2, 2012 | 05:57 PM
NintenTom's Avatar
NintenTom
Cool. I see you're in the south bay also. Did you bring it to Stevens Creek Mini or elsewhere?
Old Oct 2, 2012 | 07:40 PM
JoanieB's Avatar
JoanieB
Just had mine done today. Thank you, MINI of San Diego!
Old Oct 2, 2012 | 09:37 PM
NintenTom's Avatar
NintenTom
I wonder if they'll do my oil change too. I went in at 12.5k miles and now i'm around 19k. Too early?
Old Oct 2, 2012 | 09:56 PM
calforhelp's Avatar
calforhelp
They'll only change the oil if your light is on or if the "all knowing key fob" tells them to do it.
Old Oct 2, 2012 | 10:01 PM
JoanieB's Avatar
JoanieB
Or if you pay them to. Here's their internet coupon:
http://www.miniofstevenscreek.com/Specials_D
Ask them if they will apply it to your R56, my local dealer gives us the same price.
Old Oct 3, 2012 | 08:14 AM
Medevack1's Avatar
Medevack1
my temperature and fluid lever started to change once they did the turbo water pump and timming change recal.
Old Oct 3, 2012 | 08:35 AM
minirab's Avatar
minirab
Get mine replaced next fri. on my 12 R58 JCW. I had to call them, didn't
receive any notice in the mail.
Old Oct 3, 2012 | 05:38 PM
NintenTom's Avatar
NintenTom
Not true. I was within the 2000-3000 range and I was able to bring mine in at 12,500 miles. My service light was not on.
Old Oct 3, 2012 | 07:52 PM
YSR50's Avatar
YSR50
Hope this was fixed on the '13
Old Oct 3, 2012 | 08:10 PM
JoanieB's Avatar
JoanieB
My paperwork says that they replaced:
Replaced Coolant Temp Sensor with retrofit kit per SIM 17-08-12
Adapter Hose
Coolant hose
Cable Strap
Antifreeze/coolant
It doesn't list the thermostat housing, I might call and ask my SA tomorrow if the housing is being replaced too, that would be great.
Old Oct 3, 2012 | 08:20 PM
Bubble and Squeak's Avatar
Bubble and Squeak
This is what caused my car to die a few months back.
Old Oct 24, 2012 | 12:39 AM
ocluck's Avatar
ocluck
for my 2011 mcs, got a call from my dealer about temperature sensor 'recall' as well as timing chain tensioner. i don't know if this is a recall or campaign. apparently my dealers knows about this and they just looked up my vin# to verify.
folks with 2011-2012 should definitely call in to check!
Old Oct 24, 2012 | 04:53 AM
zre's Avatar
zre
Checked with my MA. He says cars built after Feburary '12 have new parts already.
Old Oct 24, 2012 | 05:34 AM
JMH_Show's Avatar
JMH_Show
Took my 2011 R55 to my local dealer (Mini of SF) on Saturday, for an oil change and they told me that they will be working on " temperature sensor 'recall' as well as timing chain tensioner" as well. They gave me a loaner for now.
Old Oct 24, 2012 | 07:11 AM
bmwr606's Avatar
bmwr606
my 03/2012 build cms all4 did not have the new parts,
the recall applied to my car
scott
Old Oct 24, 2012 | 11:13 AM
NintenTom's Avatar
NintenTom
My SA did mention that they were checking the timing chain tensioner as well on 2011 and newer models. Funny thing is when picking up my car up on Saturday, my check engine light came on right away and it's still been at the dealership since then. No word on what the issue is even after asking the engineers in Europe. He mentioned it may have something to do with the VANOS timing or something. =?
Old Oct 24, 2012 | 05:52 PM
mdun6's Avatar
mdun6
Took mine in Saturday for the coolant sensor recall and then got the call that is also has an oil leak. I guess they had to take off the oil pan to fix it.
My car is a 2012 Cooper S and it just turned 5,000 mile. I always noticed that when I would use sport mode it would backfire. Now that the new sensor is in i,m not hearing any backfiring.
Old Oct 24, 2012 | 08:47 PM
JMH_Show's Avatar
JMH_Show
Just got my wife's 2011 R55 back from SF Mini.
Recall: Check Chain Tensioner Leak
Performed inspection as per 0011990200. Removed intake manifold and inspected timing chain tensioner. No oil leak found. Ok at this time. Affix Recall Label to B pillar. Service completed. Parts None.
Recall: Coolant Temp Sensor
Performed coolant temp sensor retrofit as per 0017560100. Bleed and pressure test cooling system. Test drove vehicle. Ok at this time. Affix recall label to B pillar. Service completed. Parts: Coolant Hose, Antifreeze, Adapter Lead, Spacer Holder, Basics 25182
Old Oct 25, 2012 | 05:22 PM
ocluck's Avatar
ocluck
So, does the recall replace the entire Coolant Temp Sensor with the new and improve one? It doesn't look like it and just just added some different adapters/hoses to the old Temp Sensor.
Old Oct 25, 2012 | 07:45 PM
boOst spIKe's Avatar
boOst spIKe
It places a coolant temp sensor in the upper radiator hose just prior to the connection to the t-stat (modified upper radiator hose is installed in replacement of what came in vehicle) and a y cable connection (pig tail) to the original connection which allows the DME to better determine cooling strategies during vehicle operation. They do not replace the T-Stat with this campaign. If you look @ the 2013 and some late model 2012's you will notice that BMWNA and MINIUSA went back to their old T-stats because of this.
Kimolaoha
Jul 5, 2023 01:04 PM
TREX
Nov 2, 2019 07:31 PM
Cereall
Sep 5, 2019 06:05 PM
tylewis
Aug 18, 2015 06:53 AM
PSIChocolate
Aug 13, 2015 12:46 PM
