replacing brakes
Old Oct 1, 2012 | 10:19 AM
wcaston's Avatar
wcaston
replacing brakes
I cannot get the cylinder to retract on the rear . Tried c clamp will not move. Didn't have any problem on front.
Old Oct 1, 2012 | 10:34 AM
slinger688's Avatar
slinger688
If it is the rear, it would be easier to use the brake tool to rotate and push at the same time. You can also use a needle nose plier.
Old Oct 1, 2012 | 01:23 PM
martinb's Avatar
martinb
You MUST rotate the piston as it's compressed.
Old Oct 1, 2012 | 01:47 PM
Capt_bj's Avatar
Capt_bj
correct, you must rotate the caliber as you retract the rears; this is a part of the e-brake system. This is not unique to MINI but one of the systems used for e-brake on rear disks. You can do it 'by hand' but is usually easier if you have a tool.
Harbor freight sells a $6 tool and a $80 set
http://www.harborfreight.com/automot...kit-69053.html
http://www.harborfreight.com/automot...ool-68972.html
Outmotoring has something similar
Larger 'chain' auto part stores may loan you a tool as they often have tool loan programs.
B4 you break something you may want to review
https://www.northamericanmotoring.co...beginners.html
Old Oct 12, 2012 | 08:23 PM
kukaepe's Avatar
kukaepe
The $5 one from HF works great. Put the tool on a short 3/8 inch extension with a T handle or short ratchet. Hold the caliper in your left hand, push in on the piston (after you line up the right pins) and rotate clockwise....piece of cake.
thebordella
Aug 31, 2015 01:37 PM
JPMontes3
Aug 23, 2015 01:26 AM
penguinhomey
Aug 17, 2015 01:33 PM
slipmagt
Aug 17, 2015 06:37 AM
