Nitto Nt01 17 fitment questions
Old Sep 30, 2012 | 08:58 PM
jer361's Avatar
jer361
I have a set of 17x7.5 rims for track use and was looking to mount a set of Nitto NT 01 17x45x225 on them for track and autocross use. Will I have any fitment issue's going to the wider tire?
Old Sep 30, 2012 | 10:57 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
225/45-17 will fit your rim but it is a little tall for the MINI and for track use.
Typically you want close to stock tire diameter or less for lowered gearing for lower speed acceleration. If you are trying to have a better top speed then a taller tire is OK.
You have several options, using your 17x7.5" wheels these will fit:
205/40-17 tire diam. 23.5", good size for autocross and driving events, good lower speed acceleration.
215/45-17 tire diam. 24.6", a little tall but OK overall
225/45-17 tire diam. 24.8", even taller, likely heavier
235/40-17 tire diam. 24.4", same as OEM tire diam, but usually fits wheels 8-9.5" wide, still possible to use with your rim. I'd pick this size over 225/45-17.
If you want the best fit then 215/45-17 makes the most sense of the sizes available for the Nitto NT 01
Old Oct 1, 2012 | 06:24 AM
jer361's Avatar
jer361
Thanks that's great information I wound up ordering 225/45-17 because I got a good price on them they where cheaper than the 215's. Since I'm not going to be racing with them I hope they will work good on track days. I was just looking for some more grip without spending allot of money.
Old Oct 1, 2012 | 10:43 AM
slinger688's Avatar
slinger688
I have used both 215/45 17 and 225/45 17 nitto nt01 for track days. Both do fit but you have to be careful if you are lowered as it might rub especially with the 225.
Nittos are really average r-comps at best but the are cheap. They are really noisy and not as communicative as I would like before they break loose. Just be really careful with them for the first track day or two, until you wear down the release compound.
Have fun on your track days.
Old Oct 1, 2012 | 10:49 AM
veggivet's Avatar
veggivet
That is the size I use for track daze and have been very pleased with them. If you don't mind me asking, where did you get your deal from, and how much was the set?
Old Oct 1, 2012 | 11:01 AM
jer361's Avatar
jer361
I got them from discount tire direct for $170 each with free shipping. Thanks for everones help.
donniedarko
Oct 21, 2015 01:15 PM
Gen1Parts
Sep 7, 2015 03:50 PM
