Suspension KW Variant 1 Coilovers
Old Sep 24, 2012 | 03:51 PM
Jack & Coke's Avatar
Jack & Coke
I have a 2010 MCS.
I've read all the confusing threads on coilovers.
I believe the KW V1 will be the best option for me. My car is still under factory warranty but I'm still going to go ahead and install these. I don't believe if I have a major motor issue they can really void my warranty for coils
So what else do I need to purchase with these coilovers? I obvioulsy want to get the car aligned so I don't eat tires alive.
Sounds like the V1 just is bolt on and go correct?
Old Sep 24, 2012 | 06:32 PM
Jack & Coke
anyone?
Old Sep 24, 2012 | 06:38 PM
Mindspin311's Avatar
Mindspin311
If you're planning a decent drop, you will more than likely need adjustable control arms in the rear to bring the camber back into check. Something like this....
http://www.waymotorworks.com/h-sport...ber-links.html
Old Sep 24, 2012 | 07:51 PM
Jack & Coke
Thank you. That's what I was wondering. So no need for camber plates? or links?
Old Sep 24, 2012 | 07:53 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
If your going to lower the car you will need the rear adj camber links:
Please feel free to call us and we'll discuss options and figure out everything you actually will want for your build. We stock KW's so we can help you out.
WAY
Old Sep 24, 2012 | 07:54 PM
Mindspin311
Cmon man....
Old Sep 24, 2012 | 08:03 PM
Jack & Coke
WAY
Thanks. I shot you a PM on here. Never heard back. Soon as I am ready to drop the hammer I will give you a call. Looks like the 1400 KW are really about 1700 with the camber links. Are camber links the same thing as adjustable rear arms?
I've had my MINI for a few weeks. It has sport suspension package.
Old Sep 25, 2012 | 04:47 AM
S&CLC's Avatar
S&CLC
I did KWV1s, Hotchkis Racing lower control arms, and an NM Engineering 22mm RSB (middle hole) on my 2011 at 700 miles from OutMotoring and could not be more pleased. (I also ditched the heavy RFs, and added super light weight wheels). The results were more than astounding. This set-up is perfect for me. A-W-E-S-O-M-E.
Aaron at OutMotoring is quite knowledgeable, does not push for a particular brand, communicates well and promptly (Email/phone calls), very fast order turnaround and at that time I recieved free shipping and a decent discount also. (Check the vendors' forum her on NAM for the monthly dicscount "code".)
Whoever you decide to deal with, do it. Do it now. You will not be sorry.
Enjoy your MINI, that's what they're for... right?
Old Sep 25, 2012 | 09:18 AM
Jack & Coke
Thank you for the input. I am coming from the offroad world. Nothin worse then having bad negative camber. Eats tires alive and looks silly unless you are racing. Looking at the camber links I might just machine my own. I already have some heims and a big metal lathe.
I have purchased Items from both vendors. Outfront has the KW's for 50 bucks cheaper and Way has the control for cheaper LOL.
Just need to finish convincing the wife and I will drop the hammer. Can't wait!
Old Sep 25, 2012 | 11:20 AM
Bigprfed22's Avatar
Bigprfed22
Ive had mine for 2 yrs now. I lowered a little bit when i corner balanced it but never got links. The added camber wasnt bad enough to kill my tires, it wears them unevenly but not bad at all.
Old Sep 25, 2012 | 11:30 AM
Jack & Coke
Your ride looks pretty low to me in your sig
Old Sep 25, 2012 | 11:36 AM
Bigprfed22's Avatar
Bigprfed22
Lol rolling around a corner! Name:  IMG_2903.jpg
Old Sep 25, 2012 | 11:44 AM
Jack & Coke
Outfront has the kw for 1395.00 and they have 5% off right now. Seems like a pretty decent deal.
Old Sep 26, 2012 | 06:29 PM
k_h_d's Avatar
k_h_d
Whats the least amount you can lower the car with the KW coilovers? I know most people ask how far you can slam them down but I am wanting to know how close to stock they can run...
Also, which coilovers of the KW line come competely assembled with the top hats? If I were to do a suspension change I am thinking I don't want to have to take the top hats off my stock so they can stay together for easy swapping if needed.
Old Sep 26, 2012 | 08:01 PM
Blainestang's Avatar
Blainestang
I believe the minimum drop with V1s is 1.2".
Regarding keeping the stock suspension, might I recommend getting some Vorshlag camber plates to go with the V1s. The B-Spec MINI racecars use this very combination (albeit with custom valves V1s).
Old Sep 26, 2012 | 11:30 PM
k_h_d's Avatar
k_h_d
Are there brands of coilovers that will allow and ride height range that's close to stock?
Old Sep 27, 2012 | 01:15 AM
GEMSTER's Avatar
GEMSTER
So far I have only seen 2 that lower less than an inch minimum.
The highest height i found was the CROSS competition coilovers. Min height drop is 0.5". But they are not made for DD. And they cost $2.4k.
The other one is the KW Clubsport coilovers. Lowers 0.8" min. But like the CROSS coilovers, they are not made for DD, and they cost $3k....
BTW, why do you want coilovers that are close to stock ride height? Just curious
Old Sep 27, 2012 | 04:24 AM
k_h_d's Avatar
k_h_d
Performance upgrade mostly. I don't mind a little drop but for the street the mini is already a low car. Sure there is wheel gap but I am not driving a race car. My Porsche has almost the same finger wheel gap. 1/2" to 1" lower is a good compremise.
I am figuring out what to put on the car for next seasons autocross to keep the car from diving and squating so much.
Old Sep 27, 2012 | 04:36 AM
THE ITCH's Avatar
THE ITCH
Jack & Coke
Another good option for you for a street ride is the JCW springs (lowers 10mm) and Koni sports or Bilstein sports struts/shocks. These will give you pretty good performance with minimal lowering.
Steve
Old Sep 27, 2012 | 09:30 AM
KenWarren's Avatar
KenWarren
... I know most people ask how far you can slam them down but I am wanting to know how close to stock they can run...
Did you consider Megan Racing coilovers? It looks like you can retain the stock height if you want.
Old Sep 27, 2012 | 09:39 AM
Jack & Coke
Originally Posted by THE ITCH
Jack & Coke
Steve
I want to lower my car a fair amount. I also don't want lowering springs and shocks.
Old Sep 27, 2012 | 02:08 PM
k_h_d's Avatar
k_h_d
Anybody have a good source for buying the JCW springs? It looks like from Classic Mini before a NAM discount they would be about $700 for the four springs. Pricey for springs unless they are that good I guess.
Old Sep 27, 2012 | 07:34 PM
Blainestang
If you get the B-Spec version of the Vorshlag Camber plates, they include an additional spacer which raises the ride height another .25", so the car could be a little less than an inch lower than stock.
Old Feb 19, 2013 | 10:58 AM
thisshouldwork's Avatar
thisshouldwork
KenWarren,
Can you, or anyone, source the Megan coils minimum lowering height? I haven’t been able to find that info. I will shortly have a new driver in the house and to avoid possible having to replace a front bumper I’d like to have the option of bringing it back up to oem height.
RIchard Nguyen
Sep 14, 2016 11:43 AM
sssevita
Mar 20, 2016 06:24 AM
CooperSharp
Oct 12, 2015 09:21 AM
bahman
Sep 30, 2015 01:59 PM
gnhovis
Sep 28, 2015 10:56 AM
