Self-Dimming Rear View Mirror not Dimming
Old Sep 14, 2012 | 09:04 PM
ACEkraut11's Avatar
ACEkraut11
Maybe it is just me being a bit dim witted about this but my self dimming rear view mirror does not seem to work. I do have the rear hatch window tinted and I am not sure if that is causing a problem or if there is some adjustment that needs to be made. Any guesses as to what a solution might be?
Old Sep 15, 2012 | 10:35 AM
Eric_Rowland's Avatar
Eric_Rowland
I'm having the same issue. I swear it used to work. I thought it might be the rear tint, but then my window became untinted and it's still not working.
Old Sep 15, 2012 | 08:05 PM
ACEkraut11's Avatar
ACEkraut11
Is there a definite way to test the mirror to confirm it definitely works or does not? Mine appears not to work but since it is the same now as when I bought the car I have nothing to compare to.
Old Sep 23, 2012 | 07:21 AM
ACEkraut11's Avatar
ACEkraut11
Anyone?
Old Sep 23, 2012 | 08:43 AM
Eric_Rowland
When I first used mine, I tried covering up the front hole (which tells the mirror if it's dark out) during the day and saw the change in the mirror view.
Old Sep 23, 2012 | 09:20 AM
ACEkraut11's Avatar
ACEkraut11
Thanks. I will give its try.
Old Oct 24, 2012 | 12:22 AM
Eric_Rowland
ACE, if you're still out there - have you tried moving your mirrors recently? I installed power folding mirrors, and a wiring hack led to my fuse blowing. Recently fixed the hack and replaced the fuse (#35 on my car) and voila! the autodimming mirror works again!! It's an awesome change!
Once again, when I cover the front hole in the daylight (making it think it's night) I can watch the mirror dim. Driving home tonight was a pleasure!
Old Oct 24, 2012 | 01:13 AM
ACEkraut11's Avatar
ACEkraut11
I have thought about checking the fuse but not done it yet. I will put that on my to do list and report back. Thanks!
Dec 23, 2015 10:36 AM
dyeLucky
Sep 11, 2015 10:41 AM
Tylerlanger1
Aug 21, 2015 03:03 PM
Bennyboy
Aug 18, 2015 07:28 AM
dyeLucky
Aug 7, 2015 07:10 AM
