R50/53 Trailer Hitches
Old Mar 25, 2004 | 04:57 PM
LSaupe's Avatar
LSaupe
I test drove my first Mini last night (base model Cooper with a 5 speed). I inquired about mounting a trailer hitch to the vehicle and the dealer/saleman kinda skirted the issue. I have the need to pull a small light trailer (800 lbs gross) from time to time. I found two hitches out there. On by Da'Lan (for the base model Cooper only) and a two piece unit at Minimania.com. The two piece unit can accomodate the Cooper S. Have any of you used hitches before, and if so how does the Mini do with it? Would this void the warranty of the vehicle (I see the Mini has no tow rating).
Many thanks,
Larry S.
Old Mar 25, 2004 | 08:01 PM
lotsie's Avatar
lotsie
I live in Canada and have the same hitch use need as you
MINI Canada say's their not going to test the hitch that is availible on
MINI International web site , which must then, been tested???
I for one thinks that the hitch would work over here!!!!
OutMotoring
Mar 3, 2017 06:29 AM
vulkandino
Oct 31, 2015 08:29 PM
jumbojimbo
Sep 24, 2015 08:16 AM
lotiman
Sep 16, 2015 06:47 PM
Accessory Products
Sep 9, 2015 10:29 AM
