What happened to my coolant? Whipped cream!
Old Sep 9, 2012 | 11:04 AM
scatpack's Avatar
scatpack
Deleted. Thanks
Delete
Old Sep 9, 2012 | 12:58 PM
grgramps's Avatar
grgramps
Although it may look like whipped cream or mayonnaise, it's more than likely a mixture of coolant and engine oil.
Have you drained it yet?
Old Sep 9, 2012 | 01:18 PM
scatpack's Avatar
scatpack
Drained the coolant? No, not yet.
The only way I know of oil getting into coolant is a cracked block... or are you suggesting it got in there when they replaced the balancer?
The car has been running fine since I got it back, its been three weeks.
Old Sep 9, 2012 | 01:20 PM
scatpack's Avatar
scatpack
Also.. I JUST changed the oil and it looked fine. Black. But fine.
Old Sep 9, 2012 | 01:27 PM
Eric_Rowland's Avatar
Eric_Rowland
Whipped cream generally means oil and water. It's often found on the oil cap, but that's usually just water condensing on the top of the valve cover.
Check the dipstick, and it might be worth loosening the front bleed screw (just behind the radiator) and see if the coolant is running clear there.
Could be an anomaly, but definitely worth checking things out. Shouldn't have anything to do with replacing the balancer itself, but if it overheated too much you could have a head gasket issue.
Old Sep 9, 2012 | 02:51 PM
grgramps's Avatar
grgramps
The possibilities are endless. It wouldn't be the first time someone put something into the wrong hole.
A coolant change is one of the less expensive things we do for our cars, so if it hasn't been done recently, you might find it worthwhile. Also, take the opportunity to remove the coolant reservoir tank and clean it. For the present, I don't see anything alarming, yet it would get my attention.
Let's hope that others reading this thread will get the idea that checking things under the bonnet is a good thing to do.
Old Sep 9, 2012 | 05:35 PM
scatpack's Avatar
scatpack
I flushed it and refilled it. Lets see what happens. ...
Old Sep 13, 2012 | 03:13 PM
Keyser_Soze's Avatar
Keyser_Soze
Could be a cracked block, but more likely is a blown head gasket or potentially a warped head... Has the car seriously overheated anytime in the past?
Old Sep 14, 2012 | 04:39 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
My bet is on the individual who did the thermostat change. It may have been on a Monday, he could've been hung over and added oil to the expansion tank instead of coolant!
Old Sep 17, 2012 | 09:52 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Any difference after a week?
888.280.7799 | 6am - 5pm PST
Camden90240
Sep 28, 2020 12:09 PM
sempaipaul
Oct 26, 2015 05:56 PM
user 739030
Sep 16, 2015 06:03 PM
Sc00terbum
Sep 11, 2015 09:07 AM
mimaal
Sep 4, 2015 09:09 AM
