R50/53 Anyone ever experience this? Very Strange.
Old Sep 4, 2012 | 12:27 PM
quickslvr580's Avatar
quickslvr580
I drove all day and the A/C, fan, windows, etc all worked fine. I parked it for 15 min; then started the car back up and the A/C fan wouldn't turn on and the windows didn't work. I then shut the car off and and started it back up and everything worked fine. So strange. I just hope this isn't some weird computer issue or something.
Any input to this would be great.
Thanks!
** Meant to write ever instead of every
Last edited by quickslvr580; Sep 4, 2012 at 12:33 PM. Reason: Title should say: Anyone ever experience this?
Old Sep 4, 2012 | 07:07 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Check the battery connections and voltage. Strange things can happen when the battery is not connected properly or has low voltage.
Old Sep 4, 2012 | 07:43 PM
ZippyNH's Avatar
ZippyNH
+1 for checking connections and voltages....take a quick look at the grounds..both on the bat and top motor mount too. Also check that the bcm is dry, and plugs are in tight.
Old Sep 4, 2012 | 08:01 PM
chrunck's Avatar
chrunck
My 2003 R53 used to do that occasionally. Climate control wouldn't come on, or the radio would be missing letters on the display. Restarting the car always fixed it.
Old Sep 4, 2012 | 08:13 PM
davisflyer's Avatar
davisflyer
Computer hiccup. Sorta like Windows, sometimes you have to reboot...
Old Sep 8, 2012 | 04:37 PM
SteveB625's Avatar
SteveB625
My '04 did that a couple of times. I guessed that the canbus needed a re-boot.
Oct 1, 2015 12:34 PM
Oct 1, 2015 12:28 PM
Oct 1, 2015 12:13 PM
