Side marker light wiring harness repair?
Old Sep 4, 2012 | 06:29 AM
Dale Cooper FBI's Avatar
Dale Cooper FBI
Hi,
on my 2011 Mini, I had a cracked right rear sidemarker light, which was relatively easy to change. The problem is that the plug that connects to the bulb holder is also damaged. A wire is broken, and the clip that holds it to the bulb holder is missing. Does Mini make a pig-tail like replacement for the purpose of repair? Something that can be added to the two existing wires? I've looked at all the online parts books I can find, but haven't turned anything up. Any part number or idea where to look is appreciated. Thanks!
Don W
Old Sep 4, 2012 | 07:41 AM
strobeyprobey's Avatar
strobeyprobey
Yes, your dealer should have all of the parts necessary to repair that. The ETK and RealOEM.com are not clear for the part numbers on these repair harness parts.
Old Sep 5, 2012 | 07:22 AM
Dale Cooper FBI
Thanks! I found several wiring repair items but not this one, so I'll just stop by and tell them what I need.
Old Oct 5, 2012 | 06:39 AM
Dale Cooper FBI
I did get the items to repair the harness. You need (2) 61 13 0 005 199 bushing contacts, and (1) 61 13 8 365 340 universal socket. Mini Of Omaha was very helpful in getting what I needed, and they said these are fairly common parts to both Mini and BMW.
ryGuyMCS
Oct 20, 2015 02:24 PM
PSIChocolate
Aug 13, 2015 12:46 PM
DWooderson
Aug 10, 2015 09:12 AM
OutMotoring
Aug 6, 2015 09:32 AM
