R56 Rear hatch question
Old Aug 23, 2012 | 06:15 PM
larryv's Avatar
larryv
Rear hatch question
Whenever i start the Mini and get out to open the rear hatch the damn thing is locked. I then have to turn off the car and pull the key out and hit the rear hatch button, how can i change this setting if possible. Is there a rear hatch button somewhere in the car? Thanks
Old Aug 23, 2012 | 08:54 PM
MCDude's Avatar
MCDude
if all the doors are unlocked the hatch should be unlocked as well. try hitting the door lock/unlock switch inside the car while its on. If that doesn't work you may have a problem.
Old Aug 24, 2012 | 06:58 PM
larryv's Avatar
larryv
MCDude, when i hit the key fob twice then the hatch stays unlocked until the mini is put into gear. Thanks for the info.
Old Aug 24, 2012 | 07:16 PM
chrunck's Avatar
chrunck
If you don't want to press the button twice, you can program your fob to unlock all doors (including the hatch) with one press. It's one of the options using the button at the end of the blinker stalk.
Old Aug 24, 2012 | 08:08 PM
larryv's Avatar
larryv
Great info! i will do. Thanks again.
Old Aug 25, 2012 | 03:33 PM
DogT's Avatar
DogT
Does that work with the 08 too? Ours has been erratic the last year or so.
Toolman
Jan 20, 2016 06:50 AM
jeffbeckhudd
Aug 29, 2015 09:11 PM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
