03+ R53 Fan Harness Part # PLEASE!
Old Aug 23, 2012 | 05:15 PM
BoostCzaR53's Avatar
BoostCzaR53
Who has a part number for the 03+ R53 separating fan harness? Is it applicable to the 02 cars to separate the P/S fan circuit from the cooling fan circuit? If so who has a part number for it? Or a cheap source to them?
Looking to ultimately separate and eliminate ever having to replace this cooling fan ever again.
Old Aug 23, 2012 | 07:16 PM
ThomB's Avatar
ThomB
Is this something that you can find on realoem.com?
Old Aug 24, 2012 | 11:01 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Try running a search on here, I think there is also a service bulletin out there describing the "split harness fix."
888.280.7799 | 6am - 5pm PST
Old Aug 24, 2012 | 12:05 PM
healey67's Avatar
healey67
Why spend the money on the harness?? just saying.. You can just eliminate the power steering fan from the circuit (cut the wires on the fan side) and replace the fuse. everything will work normally.
Old Aug 25, 2012 | 08:25 AM
ZippyNH's Avatar
ZippyNH
Might cost you a $600 (part) power steering pump and a $200 ps fan....
The SB for the split was instructions...not a seperate harness. Basily rewiring it and moving the wire....
When i bought a ps fan, the vendor had enclosed the sb in the box, but mine was already done....think the box old fan and sb is long gone, but i think it said 1.5 hrs and a few shop supplies...assuming a bit of wire and a few connectors.....
Wohnson89
Jun 10, 2020 04:53 AM
bobbiemartin
Jan 20, 2016 05:28 PM
ryGuyMCS
Oct 20, 2015 02:24 PM
David.R53
Sep 1, 2015 06:51 PM
