R50/53 2006 R50 getrag 5 speed transmission fluid capacity
Old Aug 23, 2012 | 12:59 PM
Miami's Avatar
Miami
I am looking to change my 2006 R50's transmission fluid with Redline MTL. I cannot seem to find how many quarts are needed? This is the 5 speed getrag. Any help would be appreciated!
Thx
-A
Old Aug 23, 2012 | 07:24 PM
ThomB's Avatar
ThomB
I have the 5-speed Getrag. I bought 2 bottles of Redline and used about 1.75 of it so 2 quarts will do you fine. You fill till it overflows, so can't really tell you exactly how much will go in.
Old Aug 24, 2012 | 07:12 AM
Miami's Avatar
Miami
Thanks Thom! How is your getrag holding up? Did the mtl make a difference?
Old Aug 24, 2012 | 07:25 AM
ThomB's Avatar
ThomB
Oooooo, that's a question you really didn't want to ask. I think the diff is shot and the transmission needs replaced (131K miles). I'm getting a shaking that I can't lose and now it's getting a loud rubbing sort of sound (I think a bearing) I can still drive it, but I am not until I am taking it to the dealer to have the work done. If the diff wasn't part of the trans, I think I'd be fine, but it's a sort of sealed unit and cheaper to replace the entire thing than to try to rebuild (I've heard that from multiple sources)
But to answer your question: It does help to put new fluid in. It gets real smooth.
The good is that I have to get in there because the clutch is still the stock unit. I'll have the clutch / trans / rear main seal done at the same time.
The bad is that it's going to cost me about $3500 to have that done.
I'm past the point of no return as I've already done Koni FSD shocks, tie rods, new wheel bearings, a rebuilt drive shaft (right side) and a bunch of other work. I figure I'll be good for another 6 years once the trans is done.
Old Aug 24, 2012 | 12:01 PM
Miami's Avatar
Miami
I'm sorry to hear about that!
I've only got 35K on the clock, so I should be OK for a while.
What do you have? I'm always intrigued by 2005-2006 R50s with the getrag. I feel they are a rare breed, since an automatic was available on both the R53s and R50s those years, and manual drivers would be more likely to opt for the R53.
EDIT: i just looked through your gallery, and noticed you have a beautiful hot orange r52!!! I would keep her too I saw you also took a trip to Marco Island. My father has a home there - it is quite the peaceful place.
Aug 19, 2015 08:28 AM
Aug 19, 2015 08:27 AM
Powershift
Aug 16, 2015 05:14 PM
rphox2003
Aug 5, 2015 11:34 AM
