R60 Anyone had lower switches out?
Old Aug 21, 2012 | 07:12 AM
Mical's Avatar
Mical
Anyone have the lower switches out of your CM? I'm curious as to access to wiring on fog light switch.
I'm fitting a roadster/coupe rear center fog light and want to wire it to OEM switch so when front fogs are on rear will be also.
Old Aug 21, 2012 | 07:30 AM
shark715's Avatar
shark715
Mical, it's easy to tell from your posts that you are quite the "tinkerer"
Old Aug 21, 2012 | 07:39 AM
Mical's Avatar
Mical
haha... yea I tend to tweak/fine tune vehicles to my liking. The Mini was a perfect fit with the "you-ification" philosophy.
Old Aug 21, 2012 | 12:09 PM
SmithWerks's Avatar
SmithWerks
I also need to tap in the switches for my Hella 500 power. Looking at he switches, the entire lower panel is 1pc. It may be possible to remove 1 sw., but I know the panel comes as 1 unit w/ the switches installed(in about 4 variations no less).
Old Aug 21, 2012 | 02:30 PM
Mical's Avatar
Mical
Yea, I dabbled w/it today had "mickey" off, side panel trim and there looks to be 4 screws around speedo that has to come off and 6 screws on center panel, then it should pull forward. I saw on Real OEM that the switch panel is held on by 2 screws also.
I'm going to need more time w/it, so I buttoned it up for now until rear fog lamp assembly gets here. Will keep you posted.
Gen1Parts
Sep 7, 2015 03:50 PM
Gen1Parts
Sep 7, 2015 01:37 PM
doug5g
Sep 2, 2015 04:53 PM
Sep 2, 2015 11:15 AM
