Drivetrain Water Pump O-Ring
Old Aug 15, 2012 | 09:40 AM
ryanleeis's Avatar
ryanleeis
Water Pump O-Ring
Could someone tell me if the O-Ring on the end of the water pump is the same as the o-ring thats behind the flange that connected to the engine block. it's on a R53 MCS. Thanks just need to order a couple new o-rings wanna get the right ones
Old Aug 16, 2012 | 05:21 AM
myrzmne's Avatar
myrzmne
O-Rings
11517509186 O-RING - 34,52X3,53 2 $4.02Yes they are the same. I just replace my water pump and supercharger so I had to get these. p/n 11517509186
http://www.penskeparts.com/DiagramsM...1&rnd=03192010
Old Aug 16, 2012 | 01:09 PM
ryanleeis's Avatar
ryanleeis
thanks for the reply.. is there a certain rad fluid that I should use.. or do I have to purchase it directly from BMW ?
Old Aug 17, 2012 | 03:48 AM
myrzmne's Avatar
myrzmne
O-Rings/coolant
I've been using Prestone 50/50 with no problems. Change it every two years. 166,000 miles
Old Aug 17, 2012 | 09:32 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Zerex, Peak, Prestone work.
888.280.7799 | 6am - 5pm PST
Old Sep 3, 2012 | 06:37 PM
ryanleeis's Avatar
ryanleeis
the Prestone 50/50 mix will work ok? i wont need to mix in any water.. i know this sounds like a dumb question.. just want to make sure.
Thanks again.!
Old Sep 3, 2012 | 07:14 PM
BlwnAway's Avatar
BlwnAway
Yes, it's ok, any Good 50/50, just not Dex-cool.
Old Sep 3, 2012 | 07:40 PM
ryanleeis's Avatar
ryanleeis
Thanks Very Much!
Old Sep 3, 2012 | 08:36 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes the water pump O ring is the same on the flange.
As for coolant you can use about anything but do NOT use Dex cool pink as it will turn to gel when mixed with regular coolant.
elverado
Jan 18, 2022 02:51 AM
patsum
26
May 29, 2021 06:29 PM
YoloSapien
Sep 25, 2015 07:12 AM
one73ronin
23
Sep 22, 2015 09:56 AM
