Doesn't start!! i need more ideas
Old Aug 14, 2012 | 08:00 PM
hashishas's Avatar
hashishas
First i wanted to say that have red almost every thread about starting problems and tried to fix that car but still cannot get any results. I thought i will try to ask you guys for more tips if there are any.
Car is 2004 mini base model automatic. last week it just didn't start in a morning. All the lights, dash , radio everything works but no crank. After reading here bought new battery - no start. Removed the starter, took it to Autozone for testing - stater is fine. Put it back in, checked all connections to battery, starter cleaned all of them still no start. Checked every single fuse in a car all of them are good. Swapped relays ~25 times still nothing. Tried to start with another key nothing happened.
Last thing i did was to check power to starter. Bigger wire has the power but the smaller doesn't even when i try to start. Now this is there my knowledge ends. My only guess would be ignition switch. Any more ideas?
Old Aug 15, 2012 | 08:40 AM
ERIK06MCS's Avatar
ERIK06MCS
Possible ignition switch. Possible bad ground. What's your resistance reading touching engine block and the battery negative post or chassis ground?
May have a bad (small) wire. What happens when you supply power to that wire, essentially jump from a power source like your battery connection under hood to that small wire?
Worst case scenario your engine is seized. But obviously that seems very doubtful given what info you have.
Likely scenario could be bad wire, bad ground, bad sensor. Try playing with your gear selector running back and forth from drive to park. Try starting with car in neutral instead of park. Try borrowing scan tool from autozone to scan vehicle for faults in the ECU?
Old Aug 18, 2012 | 01:01 PM
hashishas's Avatar
hashishas
So, it was ignition switch
Getrieben
Sep 12, 2024 07:03 AM
TREX
Nov 2, 2019 07:31 PM
Gil-galad
Eastern Iowa MINIs
63
Nov 17, 2016 02:54 PM
Getrieben
Aug 17, 2016 06:32 AM
kpl
Aug 11, 2015 04:52 AM
