R50/53 alignment question
Old Aug 14, 2012 | 05:11 AM
cargod4490's Avatar
cargod4490
alignment question
Hi everyone,
Im just curious if I would need an alignment if i took my springs/shocks off to put in reinforcement plates underneath the strut towers? Would you do an alignment or should i be good?
Old Aug 14, 2012 | 07:28 AM
quikmni's Avatar
quikmni
You should be OK. The only adjustment you have on the front is toe, which should not have changed. Camber and caster or not adjustable on your car.
The plates did raise the car slightly which can change the suspension geometry but I would suspect very little change.
Old Aug 14, 2012 | 07:55 AM
Spooled's Avatar
Spooled
Adding the reinforcement plates that go UNDER the strut tower will raise the front of the car a little bit. That will cause a change in your toe. Any change in ride height changes both camber and toe. The change is going to be very slight, most likely still within factory specs, so I don't think an alignment is necessary.
donniedarko
Oct 21, 2015 01:15 PM
broncobuddha
Suspension
Sep 18, 2015 05:16 PM
Sep 1, 2015 04:39 PM
