R60 Trunk Liner (that goes into the under trunk)
Old Aug 11, 2012 | 10:32 AM
Drockfresh's Avatar
Drockfresh
Hey there:
I have a 2011 countryman. Anyone know of a trunk liner (for the trunk part that go in the underwell under the load floor flap)?
I think the weathertech goes on top of the movable load floor piece (hope I'm explaining this correctly).
Thanks,
DG
Old Aug 11, 2012 | 04:27 PM
52804x4's Avatar
52804x4
Something like this?
http://new.minimania.com/part/NMA760...--Cooper-And-S
Not sure if the floor folds flat over it though!!??
EDIT!: Never mind. . .I see now that you wanter a liner not an organizer!!! DOH!
Old Aug 11, 2012 | 05:05 PM
chrunck's Avatar
chrunck
All the ones I've seen go on top, which is stupid. Let me know if you find anything. I really want one for ski season, since boots fit under there perfectly. MINI only makes one for underneath for the Clubman, but only makes the top one for the Countryman. It's aggravating.
Found this one: http://www.bootsliners.co.uk/MINI-CO...OOT-LINER.html. Don't know how well it fits.
Anyone know if there is a different lower floor dimension for flat load vs standard? Seems like they should be the same.
Old Aug 14, 2012 | 04:56 AM
sirbikes's Avatar
sirbikes
This is what I used. Got it at Lowes. It was fairly inexpensive. Cuts easily and if you make a mistake you have a lot left over. I made a cardboard template first to get a perfect fit.
Attached Thumbnails Trunk Liner (that goes into the under trunk)-dscn0625-1-.jpg   Trunk Liner (that goes into the under trunk)-dsc_0409.jpg   Trunk Liner (that goes into the under trunk)-dsc_0408.jpg
Old Aug 14, 2012 | 06:04 AM
razz's Avatar
razz
I did the same, except I cut a scrap piece of diamond garage floor covering to fit. Of all the places to install the patented dirt-and-hair-magnet material that MINI calls "carpeting," this compartment makes the least sense.
Old Apr 24, 2013 | 12:10 PM
Cohnhead's Avatar
Cohnhead
Did you get this one?
Did you end up buying the one that you linked to below? It looks exactly like what I want, but I wonder how it fits. Can you post a picture if you got it? Thanks so much!
Anyone know if there is a different lower floor dimension for flat load vs standard? Seems like they should be the same.[/QUOTE]
Old Oct 18, 2013 | 10:10 AM
gremlin's Avatar
gremlin
Has anyone found one of these from somewhere that will ship to the states? That's exactly what I want. I'd prefer something with a lip in case I have super wet gear to o in there.
OutMotoring
Mar 3, 2017 06:29 AM
tristanwelch95
Sep 30, 2015 08:58 AM
FatherG
Sep 29, 2015 02:47 PM
BMC_Kid
Sep 27, 2015 04:31 PM
CptSlow
R59 :: Roadster Talk (2012+)
Sep 18, 2015 08:46 AM
