will this fit?
Old Mar 21, 2004 | 08:29 AM
Skoobeedu's Avatar
Skoobeedu
I am a rookie when it comes to wheels. this is the first car that I have wanted to upgrade the wheels and tires... so forgive me for being a rookie.
I am looking at some rims with the specs of 17x8 offset of 47 with a bolt pattern 5 lug 120mm.
I have an 04 MCS. Do you think that these will fit?
also lookingat 18x 8.5 off set 47, 5 lug 12mm....
Any thoughts?
Old Mar 21, 2004 | 11:19 AM
2perCooper's Avatar
2perCooper
the mini is a 4 lug with a 4-100 bolt pattern.
Old Mar 21, 2004 | 11:24 AM
Skoobeedu's Avatar
Skoobeedu
Well, that is no good. ok, well, I will see if I can find something close to what I am looking for...
Old Mar 21, 2004 | 12:31 PM
2perCooper's Avatar
2perCooper
its actually much easier to find wheels in that bolt pattern because its so common.
there are so many wheels to choose from. you will go crazy when picking :smile: :smile:
-chris
Old Mar 21, 2004 | 01:40 PM
Skoobeedu's Avatar
Skoobeedu
thanks. My fear is picking the wrong ones. anyone have any problems with flats without the run flats? do the run flats even benifit you anyways? I guess I really dont know how they really work... Its a tire in a tire right? something like that?
Old Mar 21, 2004 | 02:29 PM
Verruckt's Avatar
Verruckt
Skoobeedu,
I would suggest just reading through posts on the "Tires, Wheels, & Brakes Forum." There is SO MUCH information out there, and alot of it, at least the basic stuff that you will need to know, such as wheel OFFSET and such has been covered in depth. And I am in no way busting on you! I myself have learned an incredible amount just by reading through here. If you have any specific questions after reading through a bit, use the [Search] function in the upper right of the screen. It's great.
THese guys talk about all kinds of things such as which tires to use for what conditions, the pros and cons of Run-Flats, wheel diameter, width, tire rubbing, all the things you need to know before buying a new set of rims. Check out the Tire Rack web site, too; they have listed a bunch of wheels that will fit, along with which tires they reccommend. And are you going to lower your car? Read on!
Hanve fun, and happy motoring!
Old Mar 22, 2004 | 12:09 PM
Alex@tirerack's Avatar
Alex@tirerack
>>thanks. My fear is picking the wrong ones. anyone have any problems with flats >>without the run flats? do the run flats even benifit you anyways? I guess I really >> dont know how they really work... Its a tire in a tire right? something like that?
The advatge is that they will run for 1 hour @ 55 mph with no air. THis allow you to make it somewhere you could hanle the issue. They are OE on your mini, because you lack a spare tire. Most folks have given them up in the name of performance or comfort. seach the cite using non rf tires - you'll see a few posts!
Alex
trw92a
Aug 26, 2015 01:47 PM
Aug 25, 2015 07:11 AM
Aug 19, 2015 12:51 PM
Aug 12, 2015 01:24 PM
