Drivetrain Siezed engine?
Old Aug 4, 2012 | 01:55 PM
Minihart's Avatar
Minihart
Siezed engine?
I have a 2007 Mini S. Plenty of oil in the pan. Stopped the car. No suggestion of problem. One hour later the car won't start. Won't churn over and the starter starts to heat up. The dip stick won't come out. Only comes up about 4" then stops. Timing chain had a lot of clatter!
Old Aug 4, 2012 | 02:02 PM
Braminator's Avatar
Braminator
Uh Oh. Have a shop check it out. Hopefully the chain guides did not explode inside.
Old Aug 4, 2012 | 02:39 PM
ZippyNH's Avatar
ZippyNH
From the other thread you have...sounds like if it had lots if clatter, it was broke, and getting out of time....the fact the dipstick is stuck ....not good. Not churning (making butter), or turning over, but rather having the startr motor getting hot trying to turn a stuck, possible siezed rotating mass...not good.
Old Aug 4, 2012 | 09:16 PM
Porthos's Avatar
Porthos
Damn that sucks. Hopefully it isn't anything serious. You might want to start looking for a long block just encase.
Old Aug 7, 2012 | 04:41 PM
turtle343's Avatar
turtle343
fear the worst. when i blew a piston it would still start but only 3 cyl were running.
Old Aug 9, 2012 | 01:21 PM
mamut's Avatar
mamut
from my experience, the timing chain snapped. had the same exact symptoms. take the valve cover off and see if the chain is there. if not then you need a head rebuild, timing chain and components replacement. Or a new/refurb engine if you have the funds.
pain in the buttocks...
Old Aug 10, 2012 | 12:10 PM
Bigprfed22's Avatar
Bigprfed22
sounds like it could also be a fuel pump.
Old Aug 10, 2012 | 12:29 PM
SooperCuperErik's Avatar
SooperCuperErik
Not if the dip stick is stuck... likely a chain/guide issue imo.
Old Aug 10, 2012 | 12:36 PM
Bigprfed22's Avatar
Bigprfed22
NM didnt read that part :'-(
Old Aug 10, 2012 | 03:01 PM
Raymazing's Avatar
Raymazing
I have a disassembled long block if you need one cheap. Needs bearings and rings.
Old Aug 15, 2012 | 05:30 PM
Minihart's Avatar
Minihart
siezed
Thanks for the input. Just letting it sit for a while. I'll post when I open it up. May have interest in the long block for build.
David.R53
Sep 1, 2015 06:49 PM
Aug 21, 2015 10:07 AM
finn
Aug 21, 2015 07:59 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
