R50/53 Tick at idle
Old Aug 1, 2012 | 07:08 PM
Claurence42's Avatar
Claurence42
Tick at idle
So I noticed that while my car is idling you can hear a ticking noise coming from the engine somewhere. I'm hoping its not a lifter tick or valve tapping, but im not sure. Alot of people say it is probably just the DFI I was just hoping that someone could confirm this for me as I just picked up my MINI a week ago.
Thanks and Happy Motoring!
Chase
will update with video in a minute
Old Aug 1, 2012 | 07:17 PM
Claurence42
http://www.youtube.com/watch?v=7kB9S...ature=youtu.be
Old Aug 1, 2012 | 07:35 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Could just be a lazy lifter, but is that coming from the PCV valve ? (Top left side of valve cover )
What is your oil level and when was the last time it was changed ?
Old Aug 1, 2012 | 07:54 PM
Claurence42
My oil is a little less than half way up the end of the dipstick. I just bought the car, but it says 1400 miles till the next change. The oil is a good color and smells fine. Not sure how to check the PCV valve. It does sound like its sucking a bit of air but I assumed it was the supercharger
Old Aug 2, 2012 | 03:35 AM
-=gRaY rAvEn=-
Moderator
If you have a 1st Gen S, the Oil should be to the top of the tips concave hash marked section. If R50 then to the fill line on the strap.
As a rule when buying a used MINI from non dealer, first task would be to change the oil and filter. Use OEM filer or a MANN filter. Most of the others you would be asking for trouble.
I say this because you never know what the person used for oil last change. Maybe they went cheap and used dyno oi or improper oil viscosity/weight ? You never know. And that could contribute to noises not normally heard.
IMO especially since you are so close to a change, do a complete oil change with a premium fully Synthetic oil. I prefer Amsoil Signauture Series but some use Redline or Mobil 1 and even Castrol. Weight should be 5W-30.
Mini recomends API rating of SM or better. I dont go beyond 7K between changes. My personal preference
Doing an oil change will also put you in a position to see any other pending issues under the engine. ( oil leaks ect. )
Old Aug 2, 2012 | 10:11 AM
Claurence42
Alright sounds good thanks for all the help!
Old Aug 4, 2012 | 02:23 AM
dubstepsteve's Avatar
dubstepsteve
does the ticking only happen on a cold start and then go away after a little buit of driving?
Old Aug 4, 2012 | 07:09 AM
mini coop's Avatar
mini coop
My Mini service advisor said it because the parts are hydraulic. The ticking noise is typical until the pressure builds up and the parts are lubricated properly. The ticking noise goes away then.
Old Aug 4, 2012 | 07:21 AM
dubstepsteve
the ticking goes away once the oil viscosity changes due to oil temperature. its not typical and can be fixed with new hydraulic lash tappets. iv also heard of people using an oil additive
Old Aug 5, 2012 | 06:19 AM
mini coop's Avatar
mini coop
The service advisor says its typical............... and I own two Mini hardtops - a 2008 and a 2012 - and both have the ticking noise. If not typical then I am just lucky?
Old Aug 5, 2012 | 06:51 AM
dubstepsteve
it IS something that typically happens on the n18 and lci engines but i can assure you its not supposed to be like that. it happens because the oil passage way running into the hydraulic tappets gets clogged and doesn't become unclogged until the oil thins out from the heat and is able to squeeze into the little hole. go get into a brand new car and i promise it wont do this. id say its due to a design flaw
Old Aug 8, 2012 | 12:03 PM
walk0080's Avatar
walk0080
Old Aug 8, 2012 | 03:09 PM
ERIK06MCS's Avatar
ERIK06MCS
Only the 2007s and newer are direct injection. I believe the op was referring to a gen 1 with noise or posted in wrong forum.
I too have a loud tick on start up but im going to be pro active and replace the timing chain tensioner as ive narrowed down my noise to the passenger side of my valve cover.
Back on topic though, I agree oil additives like a bottle of Lucas may help the op with his noise if he cares to get rid of it.
Old Aug 8, 2012 | 03:11 PM
walk0080's Avatar
walk0080
Old Aug 12, 2012 | 08:45 PM
Claurence42
Hey guys just thought I would give a quick update for anybody else with this problem. I took it to my local oilstop because I was headed out on a trip and didn't have time to do a change. They drained all the old stuff out and it was topped off with some mobil1 5w-30 along with a filter and the ticking is completely gone now!
Thanks for all your help and Happy Motoring
Old Aug 13, 2012 | 05:58 AM
-=gRaY rAvEn=-
Moderator
That would be true for your R56. Wrong section.
Old Aug 13, 2012 | 06:00 AM
-=gRaY rAvEn=-
Moderator
Yeah just neeed some new/correct oil.
Good to hear.
Old Aug 13, 2012 | 07:08 AM
ZippyNH's Avatar
ZippyNH
Chase
Gen1 MINI cars with the prince motor..the r50/r53/r53 DO NOT HAVE DFI injection....that did not happen till the NEXT generation of MINI motors...
Old Aug 13, 2012 | 07:10 AM
ZippyNH's Avatar
ZippyNH
Good to hear the MODS are hard at work!!
scfiveo
Sep 27, 2019 02:27 PM
navybsn
Oct 4, 2015 03:27 PM
micromini234
Sep 30, 2015 07:36 PM
Miniwaukee
Sep 29, 2015 09:22 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
