R56 AC compressor making noise after r134a refill
Old Jul 26, 2012 | 10:26 AM
sripavan's Avatar
sripavan
HI all,
My 2008 mcs has 48000 mils and my A/C has not been working at its peak. I decided to add some r134a subzero refrigerant to it. I think I overfilled it as my compressor kept coming on and off several times with in the spam of 10seconds and this cycle kept repeating. I removed some r134a with a screwdriver from the low side port. Now it is running fine but making a lot of noise like a small lawnmower or something in there. It happens more during acceleration. If I turn off the A/C then its gone. Can some one suggest me what may be wrong. It did not make so much noise till now.
Thank You in advance..
Old Jul 26, 2012 | 08:16 PM
bluefox280's Avatar
bluefox280
Without the right equipment, there's very little you can diagnose with the AC system.
A certified professional will need to fully evacuate the system, purge, and refill to proper pressure.
Over-pressurize can result in seal damage, and the like.
- Erik
Old Jul 27, 2012 | 07:15 AM
sripavan's Avatar
sripavan
Thank You for the reply. I think so too. I will take it to the dealer and see what they say.
Pavan
Old Jul 27, 2012 | 08:11 AM
ZippyNH's Avatar
ZippyNH
Refil kits also usually include a universal oil, and a sealer of sometype...the mini system is TINY...gen 1cars have about 1 pound of 134a, gen,2 should be similar...
overfilling...with 134a and or the oil can cause issues....the different type of lube...go figure.
a dealer will cost you $$$, but most any ac shop can do it if they have the equipment...and they understand it better than a dealer guy and a few videos......
Be sure to tell them exactly what you ssif here.....
Old Aug 1, 2012 | 11:30 AM
sripavan's Avatar
sripavan
solved finally
Took it to the shop and they said I overfilled it by about 5oz. Whoa..
I have also been reading the correct procedure is always to purge/vacuum and then refill it. Assuming we need to do it once or twice in the lifetime of the car. I think its best to let a pro do it or get the right equipment and do it right way.
It cost me a total of $167 inc taxes. I did not take it to a dealer. Now its blowing cool air and no more noise as the compressor kicks in.
Thank you all for your comments.
Old Dec 8, 2016 | 01:47 PM
Christinamrivera1993's Avatar
Originally Posted by sripavan
took it to the shop and they said i overfilled it by about 5oz. Whoa..
so did you have to do anything?
Finhead
105
Aug 14, 2023 07:51 AM
Melvinyip
Apr 17, 2020 09:28 AM
damncajun
Aug 17, 2015 08:25 PM
PrimePower
Aug 16, 2015 06:29 PM
Fizzyx
Aug 14, 2015 08:24 PM
