R50/53 Squeaking noise when turning at low speed
Hey guys
Any thoughts on what it might be -- getting a squeaking noise while taking sharp turns at low speed...
Thoughts on the cause and/or cost to repair?
Not all the squeaking noises are the same, mine ( R53 ) was the steering rack, make sure that the oil level is right. Also it might need an alignment. that is the easy part, I will try that first. if not to the shop.
My car had the same problem this summer. It turned out the caliper bolts were bent. It took me taking it to the shop 2x before they figured it out. When I turned the corner slowly, it would sound like I was dragging a metal pipe along.
It could be wheel bearings as well. I'd get them to inspect your brakes/calipers/pads/etc.
silence2-38554
Nov 12, 2015 09:39 AM
R50/53 2002 R53 Creaking/Clacking
maestro39
Oct 27, 2015 02:38 PM
