215/45/17 with 32 offset?
Old Jul 22, 2012 | 11:19 PM
poolemac's Avatar
poolemac
Hey,
I'm going to be running the 17'' OZ Superleggera with a 5MM spacer to fit my brakes. The wheels are et37 so effectively it's a et32 setup.
Will I have any rubbing issues lowered on coilovers with about a 1 finger gap? Should I consider getting a 215/40/17 instead of a 215/45/17? Not sure if the smaller diameter will help avoid rubbing on the outside edge or not.
thanks!
Andrew
Old Jul 23, 2012 | 06:26 AM
J&M'sMini's Avatar
J&M'sMini
I've got a set of wheels/tires with the same offsets/spacers & tire size.
...the car was only lowered with springs, had maybe a bit more than finger gap.
Rubbed! ..mostly in the rear, and especially with a passenger or anything loaded in back.
..have just put in coilovers with 16" wheels & more low.
When I want to put those 17s back on (will adjust height of course) and not do the spacers. (have also done some trimming)
..the 215/45 might not rub if you don't use spacer (do you need w/rear brakes?)...and do some trimming.
Or just go 205/45
J
Old Jul 23, 2012 | 03:39 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Originally Posted by poolemac
Hey,
thanks!
Andrew
If you have fully adjustable coilovers you can adjust ride height to give you clearance if needed. If you have front adjustable camber plates and rear adjustable lower control arms you can use more negative camber for clearance.
205/45-17 would give you the most clearance overall for your wheels and 215/40-17 is workable and less tall than stock.
215/45-17 is not the best choice since it is about 0.4" taller than stock and a little wider as well.
The more you lower your suspension the less clearance you may have. If you do not want to go more negative on camber or adjust your ride height up then pick tires that are not wider and taller than stock.
You can also trim the black plastic inner wheel arches with a dremmel for more clearance.
Old Jul 23, 2012 | 09:31 PM
poolemac's Avatar
poolemac
Yeah, that's kinda what I was thinking. Thanks for the feedback guys. Since I don't have adjustable camber plates (yet), I'll probably go with the 215/40.
Am I going to notice the offset difference? if I decide to not run the spacer in the rear? I'm guessing it's subtle...
Old Jul 26, 2012 | 01:14 PM
J&M'sMini's Avatar
J&M'sMini
^^ visually the 5mm is not that noticable.
but that 5mm can make a big difference when it comes to rubbing.
bahman
Aug 6, 2016 07:19 AM
Chibi2
May 19, 2016 03:46 PM
Amberleigh MacIntyre
R55 :: Clubman Talk (2008+)
Nov 11, 2015 11:59 AM
vbmike
Oct 15, 2015 04:32 AM
