R56 Cant i isntall in my r56 N18 engine a bov?
I would like to know is that posible because some people had told me that the n18 engine do not do vacum i have a aftermarket HKS bov but i would like to know if have to buy anything else to install it and works perfectly let me know thanks!
Remember that the N14 and N18 are closed-loop boost systems.
That means the unused boost, when you throttle lift, is diverted back into the intake system.
Venting boost into atmosphere can results in a fuel trim issue as the ECU thinks the unused boost is still accounted for in the intake system.
Search and you'll find owners with them.
- Erik
- Erik
Forge Bov for r56 n18 engine
I been searching and i saw that the forge bov cant be install in r60 that the engine code is (Turbo N18B16MO engine) that is the same for the mini cooper s r56 2011 turbo so it cant be install in the r56 but i would like to know the feedback about it if some one have install it in a r56 n18 engine??? Thanks
