R56 Need Help!!! 2007 R56 s Temp warning light!
Old Jun 28, 2012 | 02:10 PM
Grenadearmy0299's Avatar
Grenadearmy0299
I have recently purchased a 2007 R56 s and about two days ago my fan started running constantly and my temp light would come on. I found it weird that my car would not act as though it was over heating nor would it leak any kind of fluids. I read it may be the Coolant Temp Sensor that needs to be replaced. Any words of advice would be greatly appreciated!
Old Jun 28, 2012 | 02:59 PM
bluefox280's Avatar
bluefox280
You've confirmed that the coolant system is properly up to level with OEM coolant?
And you're 100% sure there's no leaks?
Then is time to check the thermostat housing and the coolant temperature sensor (CTS) for shortage or failure.
- Erik
Old Jun 28, 2012 | 03:28 PM
Grenadearmy0299
Yes, My coolant levels are perfect and my MCS sits on a black top drive way and I've been checking for leaks and there has been no puddles. If it was my thermostat would that cause a leakage of fluids? Thats why Im thinking it may be the coolant temp sensor.
Old Jun 28, 2012 | 03:44 PM
bluefox280's Avatar
bluefox280
Yes, a coolant temperature sensor (item #5) is the place I would start as well.
- Erik
Cereall
Sep 5, 2019 06:05 PM
Dec 23, 2015 10:36 AM
JamJam43087
Aug 16, 2015 02:02 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
