tire pressure
Old Mar 15, 2004 | 05:31 PM
lady's Avatar
lady
OK...please don't make too much fun. The manual says 33 psi for a MCS. The sidewall of the (performance) tire says something like 51 psi. That's quite a difference. How much should my tires be inflated?
Old Mar 15, 2004 | 06:07 PM
2perCooper's Avatar
2perCooper
keep it at 33 psi...
the 51psi that the tire says is the max tire pressure the tire can hold. do not exceed the max pressure that a tire can hold. hope that helps
-chris
_________________
Mods: tint (35%)
Soon to be Mods:
black aero grills,
Enkei RPM2 17"
MiniCD's Avatar
MiniCD
Take a look at the sticker in the door. It has different pressures depending on tire size and load of the vehicle. Use this as a guide.
The number on the sidewall is the tire manufacturer's "Maximum Inflation Pressure" which is used for calculating maximum tire load and speed, and is applicable to any vehicle the tire is used on, not just the MINI.
khumpert
Nov 30, 2015 11:48 AM
oldkid6
Aug 30, 2015 08:28 AM
TJANK
Aug 24, 2015 06:11 PM
nomar116
Aug 9, 2015 09:42 AM
