Oil pressure related noise; lifter or rod
Old Jun 20, 2012 | 11:05 AM
Srcypher's Avatar
Srcypher
I have an oil pressure dependant noise that at startup,
  • Goes away when the idiot light goes out
  • Is longer in length and more often the longer the car sits
  • But isn't there 100 percent of The time
  • Slight rattle but not a loud bang
  • Never comes back, no matter how hot or how long the car runs
Oil pressure cold is always 75+lbs
Hot at idle is 17-20 lbs
Hot at 3200 rpm = 50lbs
39000 miles
2006 gen1 JCW
The only thing that has changed recently is I used 0-30 Mobil 1 European formula, but the noise has only become noticeable the past couple weeks. Before that it was whatever the stealer had put in it. I bought it at 29000 miles in December.
Since it is so short in duration, and dependant on a long wait in between "tests" what should I look for to assess if its rod knock or lifter related?
-Scott
Old Jun 20, 2012 | 11:25 AM
ThumperMCS's Avatar
ThumperMCS
Sounds like the timing chain tensioner to me
Also, try using M1 0W-40 instead of 30
Old Jun 20, 2012 | 07:45 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I have replaced many timing chain tensioners lately so it's possible.
TREX
Nov 2, 2019 07:31 PM
maestro39
Oct 27, 2015 02:38 PM
patrioticmini
Aug 20, 2015 10:54 AM
Emnotek
Aug 13, 2015 05:47 PM
