Replace alternator through the wheel well liner?
Old Jun 18, 2012 | 05:04 PM
mikeym's Avatar
mikeym
Title says it all... has anyone done it? Not looking forward to putting the car in service mode...
Mike
Old Jun 18, 2012 | 05:26 PM
minsanity's Avatar
minsanity
Doubt if there is enough room to pull it out thru the wheel well. Looks like service mode is the way to go.
Old Jun 18, 2012 | 06:20 PM
mikeym's Avatar
mikeym
Minsanity thanks for the response. Gonna leave up for a few days to see if anyone has done or tried. Hoping to tackle this weekend...
Does anyone have the writeup for removing the serpentine belt too without the tool? I understand how its done, but maybe someone has a DIY.
~mikeym
Old Jun 18, 2012 | 09:30 PM
clay44's Avatar
clay44
The belt is easy. 16mm socket on the tensioner bolt by the supercharger pulley to use as a fulcrum. Alan key in one of the 2 holes towards the back of the tensioner to lift the tensioner up. Then use something long like a pry bar (i use a 30 inch long wood clamp) to release the tension. When it's loose put a small screw driver in the 2nd hole that come out of the back of the spring.
Pretty sure that it's not possible to do the swap from the wheel well.
Old Jun 20, 2012 | 07:48 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Sorry but you can't replace the Alt through the wheel well. Front Service mode will get it done.
Old Jun 20, 2012 | 08:38 PM
mikeym's Avatar
mikeym
Thanks guys. I will go service mode.
Doesn't look too bad. There's some good threads here. I just don't have the bentley so if I screw it up
I'll be posting here again....
eliseo1981
Jan 28, 2021 02:45 PM
iamcamkeenan
Aug 10, 2015 03:31 PM
nismo4life
Aug 5, 2015 08:31 AM
