R127 5 Star Double Spoke wheels or NM Eng RSe07 wheels?
I'm getting my CMSA4 this week...I really wanted the sport package and the 18" 5 star double spoke wheels in anthracite, but there was nothing out there the way I wanted it, and due to time constraints, had to take what I can get. My car will have the 17" 5 star double spokes in black with A/S tires, which I'll use for 3 seasons, and want to get a set of 18's for the summer season. Question is, do I get the R127's, or the RSe07's? On the plus side for the NM's, I can get the RSe07's a LOT cheaper than the R127's, and I'll bet they are at least 5-6 lbs lighter on each corner. But I like the look of the R127's much more. Plus with the Light White color I am getting, would much prefer an anthracite color wheel over black, but i'll deal..
What do you think?
or
Also, as much as I would love to have 19's, the roads here will destroy them, so unfortunately 19" wheels are not an option for me...
This is what NYC roads did to me last year...and this was with 17's...
What do you think?
or
^ I think I really need to see the RSe07's on a Countryman to decide though...I see their stock pic on a Hardtop with them, but it's hard to compare that to how it would look on a Countryman.
The above stock photo shows a 4 lug wheel. The RSe07 AND RSe14 are both available as a 5 lug wheel for the R60. The RSe12, which is the 4 lug version of the RSe14, will fit the other MINI models.
Surely you don't think I'm THAT stupid to not know the difference between a 4 and 5 lug wheel and what cars can use what, especially in the images above of the R127 clearly showing a 5 lug and the RSe07's showing a 4 lug...
http://www.outmotoring.com/nm-engine...-18-wheel.html
Originally Posted by Outmotoring.com
The NM RSe07 is a wheel with unmatched quality, perfectly spec-ed for your Mini. With its design adapted from the European touring challenge cars and weighing just a mere 18.5 Lbs., the RSe07 will enhance your motoring experience cosmetically as well as performance by reducing the rotational mass or unsprung weight.
Specification:
Offset: +45 mm
PCD: 4-100mm (For gen1 and gen2 MINI; 5x120 for R60 Countryman)
Bore: 56.1mm
Lug Opening: 14mm Conical Seat
RSe07 is OEM TPMS (Tire Pressure Monitoring System) compatible but NOT included.
RSe07 utilizes OEM Mini or JCW center cap as well as mounting lug bolts, which are not included with the wheel.
Notes:
OEM Part #:
'MINI' Center Cap: 36131171069
'JCW' Center Cap: 36136778917
Part # Color Each
NM.880701S Silver $279.95
NM.880701B Black $279.95
NM.880701G Gun Metal $279.95
Specification:
Offset: +45 mm
Bore: 56.1mm
Notes:
OEM Part #:
Part # Color Each
I much prefer the NM wheel you posted. I don't like two-town wheels as I think the machined edge makes the wheel look functionally smaller. It makes an 18 look like a 17 to my eye.
The little laser-etched "NM" is tight, too. I vote NM all the way between these choices.
Out of the two I also like the NM. The dealers around here must push the OEM 18" R127 wheel because just about every time I see a CM on the road it has those wheels. I like the R127 but I wouldn't want it just to be different. And like Hujan said, when the spokes extend all the way out to the edge of the rim (like they do on the RSe07) instead of stopping short and then having a lip, it visually makes the wheel look larger.
I entered the car info for the R60 on their website, and the RSe07 wheel comes up. However, the specs read this....
Specification:
Offset: +45 mm
PCD: 4-100mm
Bore: 56.1mm
Those aren't the specs for the R60. So something is wrong on their website. Either they do have a version for the R60, and mistakenly listed the specs for the hardtop. Or, it doesn't fit the R60, and it mistakenly comes up in the search when it shouldn't. Maybe I'll email them and see what the real story is.
Specification:
Offset: +45 mm
PCD: 4-100mm
Bore: 56.1mm
Specification:
Offset: +45 mm
PCD: 4-100mm
Bore: 56.1mm
Specification:
Offset: +45 mm
PCD: 4-100mm
Bore: 56.1mm
You must have called them at the same time as I just emailed them! Here is the email I just got...
Hi Greg,
Sorry, that was an error on our site. We currently do not have the application yet, but hopefully we will before the end of the year.
Thanks,
Jerry T
NM Eng.
On Jun 18, 2012, at 12:42 PM, Greg wrote:
When I enter the car info for the R60 Countryman it gives me a couple wheel choices, and one of them is the RSe07. However, the specs listed are for the MINI hartop with a 4x100 PCD. Do you have a version of the RSe07 for the Countryman with a 5x120 PCD as well?
Do you like the TSW Interlagos from the other thread? If you want 18s those would be a great option; lightweight, good looking, and reasonably priced. On that chart that you posted, the size (18x8+35) looks good, the only thing to find out is if the centerbore is large enough... it needs to be 72.56mm or larger.
If you like those, here is the fitment shown below. The 8.5" wheel with 42 offset is what I have, and it fits fine even with the lowering springs. As you can see, the 8" wheel with 35 offset would leave you much more clearance on the inside, and the outer face of the wheel would only move out a half a millimeter, which is basically nothing.
Hi Greg,
Thanks,
Jerry T
NM Eng.
devicemanager
Jun 17, 2016 06:18 PM
Dec 23, 2015 10:36 AM
AdrenaliNate
Aug 24, 2015 12:37 PM
