2003 Swap 6 speed for 5 speed?
Old Jun 15, 2012 | 07:11 PM
Dave Koch's Avatar
Dave Koch
I am a frustrated 2003 Owner and need to replace the tranny. It seems that the 6 speeds are quite a bit cheaper. I know I will sacrifice MPG but would like to know if a swap is possible and what I may have to do to make it happen..... I know that some of you guys and gals are very knowledgeable about this stinkin 2003, please help me out....
Thanks,
Dave
Old Jun 17, 2012 | 10:29 AM
clay44's Avatar
clay44
With all the extra work you would have to do to swap to a 6 speed you'll end up spending more than if you would have stuck with a 5 speed. There is a thread on here with a looooooong list of other things that would need to be changed out as well.
Old Jun 17, 2012 | 12:45 PM
cristo's Avatar
cristo
Alliance Member
Main advantage of changing from a 2003 5 speed (Midlands) transmission to a
6 speed is to avoid the unreliability of the somewhat failure prone Midlands unit.
Changing to a Getrag 5 speed is also a step up in terms of reliability, but either
way you need to change a lot of stuff to do the swap from Midlands to a Getrag
5-speed or Getrag 6-speed compared to swapping to another Midlands.
Extra parts include transmission mount, clutch, flywheel, axles, starter mounts, clutch slave and tubing, extend reverse switch harness, etc.
Old Jun 20, 2012 | 07:50 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
It will cost you more to put the 6spd in as you'll need the complete clutch and flywheel kit, shift cables, axles, mount, new intake, and a few other things.
M7Speed
Aug 18, 2015 05:18 AM
M7Speed
Aug 14, 2015 01:50 PM
M7Speed
Aug 14, 2015 01:46 PM
M7Speed
Aug 14, 2015 01:45 PM
M7Speed
Aug 14, 2015 01:42 PM
