R56 Anyone try these yet?
Old Jun 15, 2012 | 10:57 AM
DVUS CPRS's Avatar
DVUS CPRS
Anyone tried these for replacement brake disc? If so, what are your thoughts about them?
Also, do you have to replace the brake pad sensor ever time you change pads, or only if the pads get totally worn down enough to activate the sensor?
Thanks.
Old Jun 15, 2012 | 11:55 AM
Slave to Felines's Avatar
Slave to Felines
Try what?
Old Jun 15, 2012 | 11:59 AM
DVUS CPRS's Avatar
DVUS CPRS
My fault lol. Forgot the link whiile sorting out tires.
http://www.nm-eng.com/254/4/0/2535/n...set-front.html
Old Jun 15, 2012 | 12:20 PM
Porthos's Avatar
Porthos
F that way too expensive for a set of rotors.
Old Jun 15, 2012 | 12:30 PM
DVUS CPRS's Avatar
DVUS CPRS
I'm sure they won't be as pricey from a retailer. Although, I'm having trouble finding anyone that sells them.
Old Jun 15, 2012 | 05:34 PM
bluefox280's Avatar
bluefox280
...way too expensive for a set of rotors.
You do realize that price is a for a pair and they are CHEAPER than the OEM 294mm x 22mm slotted rotors...
- Erik
Old Jun 15, 2012 | 06:40 PM
DVUS CPRS's Avatar
DVUS CPRS
HA!! Found'em!!! Like I thought, much cheaper than retail too.
http://www.oxspeed.com/app/site/main...C-606493437D3B
Old Jun 15, 2012 | 07:31 PM
Porthos's Avatar
Porthos
Don't do it. I got Powerslot rotors and have had them with EBC reds for 25k miles and there is little to no wear on them.
I had cryos on my last car and I can tell you that you can see a serious amount of life out them.
http://www.autoanything.com/brakes/61A2723A0A0.aspx
Here is what I have now on the MINI
http://www.autoanything.com/brakes/6...0A3224770.aspx
Old Jun 15, 2012 | 08:11 PM
tommybwell's Avatar
tommybwell
I wonder why slotted and drilled are less than just slotted?
Old Jun 15, 2012 | 08:13 PM
smoke05S's Avatar
smoke05S
Why $73-$93.00? With my luck it is always the higher number.
