Suspension Countryman All4 with R53 JCW suspension
Hi everyone!
Here's a picture of my 2012 CMS All4. I just installed a R53 JCW suspension on the front, and I'll do the rear today. The fitting was pretty easy, keeping the CMS top plates and I'll need adjustable link kit.
These are BMW replica wheels... 17x8 +35
EDIT: Oh, and the stickers are from my Autocross club, in Quebec City!
The rear is a bit low, and there's rubbing :( With OEM wheels it'll be ok!
And for the weight, I'm not really afraid... JCW springs seem to have better spring rate than my stock CMS springs.
I'll probably put a spacer between the rear top plate and the car about 1/2''
Were you able to get the alignment as per specs?
Didn't got the time for the alignment. For sure I can't get the OEM camber, tires are rubbing enough like this!
But I'll try at least to reajust toe...
Oh and I will try soon whith my race tires (235-40-17) on OEM wheels... I think it wont rub anymore!
So the only thing different is the top hats of the struts? The struts are the same dimensions on the bottom and slip into the R60 front knuckles with no problem?
Yes, you should be fine once you increase the offset from +35 to the stock +52.
I did this on my R53 to get the rear ride height where I wanted it. You've got to love the simple way the MINI rear suspension attaches to the body!
Where do you find this spacer??
On my R53 I just cut four square pieces of aluminum plate of the thickness I wanted, and drilled a hole in the middle of each. Only cost a couple of bucks and worked great, had them on for around 50k miles until I sold the car. I think most people made their own like that, rather than buying the expensive machined spacers, maybe that's why they stopped making them.
Here's an old thread... https://www.northamericanmotoring.co...t-spacers.html
PS - When you put your adj. lower control arms on, what did you set the rear camber to? Somewhere around -1.5?
No way.. I still think that is too much. I started at -.5 then finally settled on -.8ish
I feel that -1.5 although performance in turns will be great, real world application of daily driving that -.5 to -.8 is the best alternative.
One thing to note, Specs for our cars: -1.5 to -1.8
He was better off before he paid them to screw up his car, those tires aren't going to last long like that.
iwant2knowwhois
11
Sep 19, 2015 12:18 PM
Minibeagle
Aug 13, 2015 10:00 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
