TSW 19mm Sway Bars are Back
Old Jun 10, 2012 | 06:22 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Way Motor Works is pleased to have the TSW 19mm rear sway bars available again. These sway bars will fit all MINI's except Countryman. If you're looking for a cost effective bar, that won't give you problems look no further. These 19mm bars are solid steel bars, with 3 adjustmen holes, and the bushings have a nice grease channel with zerk fittings on the mounting brackets to regrease them later if you need. Bar comes in black so it blends right in with the rest of the suspension, great if you worry about warranty.
W0TM8
Dec 19, 2019 07:50 AM
minipopkart
Aug 13, 2015 05:22 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
