R56 High speed fan
Old Jun 10, 2012 | 12:30 PM
MiniPug's Avatar
MiniPug
High speed fan
I have watched my water temps drop from the 220 range to 175 by using the max AC. I know the high speed fan runs while this setting is used. Has anyone figured out a way to manualy turn off / on the high speed fan via tapping in and using a switch?
This is a trick used on late model Mustangs.
Old Jun 10, 2012 | 01:16 PM
bluefox280's Avatar
bluefox280
Sure, do exactly what you said; tap in a bypass switch.
However, the direct injection engines like to run hot (around ~220F) due to emissions controls and proper burn efficiency.
- Erik
theblackfalcon
Oct 11, 2015 09:49 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
Pyrs
R55 :: Clubman Talk (2008+)
19
Sep 8, 2015 01:43 PM
David.R53
Sep 1, 2015 06:51 PM
