R56 Water Pump and Thermostat Housing
Old Jun 5, 2012 | 08:39 PM
Ch28Kid's Avatar
Ch28Kid
Hello NAM
So a couple days ago my car radiator fan was running at max the whole time and scanguage reads 126C the whole time I was driving. I knew my Thermostat had some issue since it was throwing a CEL code P0599.
Went to MINI dealer and they said my water pump was leaking too and it would cost me $1300 to get everything fix. 500 for Thermostat + 650 Water Pump.
They are charging me 5.1 Hour of labour for the whole job.
I was just wondering if the Thermostat and Water Pump is located in 2 different area? Shouldn't the labour on Water pump overlap the labour on the Thermostat?
Can anyone help me?
Old Jun 5, 2012 | 11:17 PM
Benibiker's Avatar
Benibiker
I think the water pump is on the left side of the engine (drive belt) and the thermostat is on the right side where the radiator hoses attach to the engine.
Old Jun 5, 2012 | 11:31 PM
timwu12's Avatar
timwu12
the 2 items most definitely are always located in 2 different locations. The water pump is driven by the timing chain and the thermostat sits in a housing that's inline from the radiator hose to the head.
Old Jun 6, 2012 | 05:15 AM
schatzy62's Avatar
schatzy62
Totally correct.
As for the 5.1 hours of labor. they will probably get it done in about 2-2.5 if the tech knows what he is doing but they will charge the standard flat rate as it is a dealership
I did my thermostat housing in less than 2 hours and i had never done one before. I could change one now in about 45 mintues.
You may want to consider a private shop for this work. It will probably save you 30+%
Old Jun 6, 2012 | 02:34 PM
hbr's Avatar
hbr
I thought there was a recall on the water pump?
Old Jun 6, 2012 | 04:32 PM
MINIdave's Avatar
MINIdave
Only the secondary electric water pump that cools the turbo after shutdown, not the main water pump......
ch28kid, the only overlap is in draining and refilling the cooling system.
Old Jul 12, 2012 | 03:12 PM
Cawtou's Avatar
Cawtou
Was it hard to change the thermostat housing? I was thinking about doing the same cause there is definitely a leak there after the recall for the aux pump. And i've had issue from dealer where they put screws in wrong places so i dont trust them anymore.
Originally Posted by schatzy62
Totally correct.
Supertractor3
Apr 7, 2017 11:16 AM
CaptKen
R59 :: Roadster Talk (2012+)
11
Oct 21, 2015 06:32 AM
molala
Oct 2, 2015 01:53 PM
mimaal
Sep 4, 2015 09:09 AM
Sep 3, 2015 10:29 AM
