R56 Are these typical issues?
Old Jun 4, 2012 | 10:15 AM
ragingMINI's Avatar
ragingMINI
As you can see, my overhead console looks like the carpet should be tucked around the black lip. Also, you can see some internals of the hidden compartment from the dash panel. Are these things typical problems or was this car tampered with before I bought it?
Attached Thumbnails Are these typical issues?-photo-3.jpg   Are these typical issues?-photo-2.jpg   Are these typical issues?-photo-4.jpg
Old Jun 4, 2012 | 01:01 PM
pheatton's Avatar
pheatton
Looks like someone has had those areas apart and didnt quite put it all back together correctly....
Old Jun 4, 2012 | 01:10 PM
ragingMINI's Avatar
ragingMINI
that's what i figured, but I couldn't tell. There doesn't appear to be evidence of damage, it just doesn't look like others I've seen. It's stuff like this that drives me crazy!
Old Jun 4, 2012 | 02:26 PM
highlander709's Avatar
highlander709
Might be residual of radar detector installation and removal.
Old Jun 5, 2012 | 07:59 AM
walk0080's Avatar
walk0080
Yup the black piece should be tucked under the headliner - should be easy to fix. Like others said, possibly just a poor job or removing a radar detector install prior to selling as it appears you have a 2009 which is obviously not factory new.
Those clips visible on the upper glove box is normal.
Old Jun 5, 2012 | 01:59 PM
yiancar's Avatar
yiancar
the 2 rollers on the secret compartment is normal, but u can fix it. however you need to remove the bottom black trim, flex it a bit, which is kinda a pain
Old Jun 5, 2012 | 04:13 PM
the matey's Avatar
the matey
The glovebox part is hard to say, I have seen some customers MINIs that look like that and others I haven't, mine isn't like that. I have also seen it on new MINIs every once in a blue moon.
Toolman
Jan 20, 2016 06:50 AM
Aug 27, 2015 03:18 PM
Accessory Products
Aug 25, 2015 10:03 AM
Aug 24, 2015 02:47 PM
Aug 21, 2015 11:25 AM
