FS:: Kicker 4 Channel Amp
Category: Navigation & Audio
Price: $75
Part fits (you may select multiples): Electrical
- Like new
- ZX Series 4-Channel Class AB Car Amplifier
- RMS Power Rating:
- 4 ohms: 60 watts x 4 chan.
- 2 ohms: 90 watts x 4 chan.
- Bridged, 4 ohms: 175 watts x 2 chan.
- Max power output: 350 watts x 2 chan.
- MOSFET power supply
- LED power and protection indicators
- Tuned Bass EQ (0-18 dB bass boost at 40 Hz)
- FIT (Fail-Safe Integration Technology) utilizes differential inputs to reject noise and electrical interference for the quietest operation possible and ultimate audio clarity
- Balanced differential inputs make KICKER ZX Amplifiers compatible with any factory radios
- Eliminates unwanted noise in a system
- Boost, gain, and crossover frequencies are top-mounted for easy access, and a handy protection indicator featuring a new flashing yellow low-voltage light enhances the end panel
- Bridgeable operation
- Speaker-level inputs compatible (switchable) through RCA connection
- Automatic turn on modes: remote, DC offset, or signal sense
- Thermal, voltage, and short circuit protection circuitry
- Variable high-pass filter (50-200 Hz, 12 dB/octave)
- Variable low-pass filter (50-200 Hz, 12 dB/octave)
- Frequency response: 20-20000 Hz
- New front panel allows customization with decals
- CEA-2006 compliant amplifier
- Dimensions: 13-1/2"L x 9-5/8"W x 2-1/8"H
- 8-gauge power and ground leads recommended
Navigation & Audio HK Replacement With New Components
Filmy
15
Jun 6, 2023 06:27 AM
gar56
Nov 15, 2016 06:41 AM
