Low Speed fan runs all the time when car running
Old May 27, 2012 | 02:57 PM
banzairx7's Avatar
banzairx7
My low speed fan(drivers side) is on constantly as soon as the car is running. Engine temp will be well below normal and the AC is not on. I've seen people have problems with the fan staying on after the car is off or not working at all but not this. Any ideas where to start hunting for the problem?
Old May 27, 2012 | 08:35 PM
minsanity's Avatar
minsanity
It may not be normal, but as long as it turns off when you shut your engine & the hi- speed fan works when it reaches the temp it needs to function or when a/c on, then it should be good if not better than how it was designed to be. Others even opt to switch to a lower temp thermostat to keep the engine cooler.
Sexual Chocolate
Mar 31, 2019 08:02 PM
phrza81
Oct 10, 2015 11:37 PM
fm.illuminatus
Aug 10, 2015 12:15 AM
