R60 Acceptable tire sizes?
Old May 25, 2012 | 12:23 PM
troukhad's Avatar
troukhad
Currently I have ContiProContact 205/55 R17
I need to change 2 front tires. I understand that I cannot change 2 tires on All 4, so looks like I need to replace all 4 tires.
What size options I have?
BTW, I don’t want to spent a lot so I am contemplating to replace them with non run flats.
Old May 25, 2012 | 01:05 PM
Mojito's Avatar
Mojito
theres a few depending on if you want more cushion or performance.
I went with 225/50 r17, Michelin Pilot Sport A/S Plus
Old May 25, 2012 | 01:46 PM
troukhad's Avatar
troukhad
So i have to create 2 columns - cushion and performance, 225/50 R17 goes to which one?
Old May 25, 2012 | 02:41 PM
52804x4's Avatar
52804x4
That size tire could go in both columns, or one or the other. It all depends on the tire you choose. Any not run-flat is going to give you more "comfort", Unless you start getting into a 40 series tire, which will start to put you back into a stiffer sidewall.
Old May 25, 2012 | 02:59 PM
DR61's Avatar
DR61
Lots of discussion and info here:
https://www.northamericanmotoring.co...nd-brakes-367/
Old May 25, 2012 | 03:24 PM
Mojito's Avatar
Mojito
Here's a calculator to help show the difference between the sizes. A taller tire will make for a nicer ride.
http://www.miata.net/garage/tirecalc.html
This can also help get your speedo closer to where it should be.
Kimolaoha
Dec 5, 2020 09:32 PM
kazyn
Oct 25, 2019 02:34 PM
bjcarter2
Aug 31, 2015 04:03 PM
col127
Aug 21, 2015 02:11 PM
Edgar78
Aug 15, 2015 05:33 AM
